04-15-2013, 09:15 PM | #1 |
Thanks Richard in Florida
It is such a pleasure to be able to take people at their word. I had the pleasure of buying a 55 Buick Carter WCFB carburetor from Richard in Florida last winter and finally put it on the roadster today. It is the best thing I have done to the flathead and puts the 390 cfm Holly I had on it to shame. It is the perfect addition to the SBC distributor Charlie in New York converted. John in Tennessee is indeed a happy camper. Thanks Guys.
John Long
Just slightly abrasive |
04-15-2013, 10:24 PM | #2 |
Re: Thanks Richard in Florida
i would also like to thank richard for all the help he has given to me over the years trev
04-15-2013, 10:45 PM | #3 |
That's my boy, I got him to buy a lathe. He's like a kid in a candy store, no tellin what he'll come up with next.
04-15-2013, 10:46 PM | #4 |
04-15-2013, 11:10 PM | #5 | |
John
04-15-2013, 11:22 PM | #6 | |
My latest project is restructuring (major surgery) a "Big Cap" Chevy HEI distributor housing for the flathead and replacing its ugly coil in the cap with a central terminal for a remote coil. Is the Big Cap ugly? Oh my, yes. But the design has some advantages and I just want to see how well it works. |
04-15-2013, 11:34 PM | #7 | |
John Long
04-15-2013, 11:56 PM | #8 |
Distributor Fantasies
I'm also looking forward to trying out my vintage Mallory dual-point. I converted it into a magnetic trigger for use with an HEI module or my MSD box, maintaining its original appearance. Even the big brass condenser is in its place, but the twisted connection link is plastic! It works great on my machine, but some roads run will be the acid test.
04-16-2013, 03:03 AM | #9 |
Ya' lathes can be fun. Just converted a Mallory Unilite made for GM to a Pertronix mag. trigger.
04-16-2013, 08:16 AM | #10 | |
John
04-16-2013, 08:40 AM | #11 | |
I always photograph every detail of every project but it's still early in this one. Here's a little teaser. |
04-16-2013, 11:22 AM | #12 |
I think I've seen that on one of the XXX rated channels.
04-16-2013, 11:34 AM | #13 |
That does deserve a little explanation........
04-16-2013, 03:18 PM | #14 |
Those are the two topside parts of the new remote coil high voltage connection. I turned the bottom piece from Delrin rod in my new lathe.
04-16-2013, 03:45 PM | #15 |
richard i have said this before this site and others just show what guys in there sheds can make i take my hat off to you all trev downunder
04-21-2013, 09:24 PM | #16 |
in what way do you prefer the carter over the holley?
04-21-2013, 10:22 PM | #17 |
I could never get the accelerator pump right on the Holley. I had tried numerous pump nozzles and pump cams but it always had a flat spot. I could see a good stream coming out of the shooter nozzle and went as small as .025 and up to .036 I think. About .029 was about the best but still never was right. The Holly tech support said .031 was what they recommended I start with.
Anyway, the WCFB is more vintage correct and is really doing a good job. Need to buy a Holley? John Long
12-14-2013, 06:34 PM | #18 |
How do I contact Charlie in N.Y. ?
12-14-2013, 06:35 PM | #19 |
Where did the 390 fall short?
12-14-2013, 06:56 PM | #20 |
Never mind, I see your previous response.
