Old 05-09-2010, 06:42 PM   #1
Ray A from PA
Ray A from PA's Avatar
Default Lug Nut Torque
My memory tells me the lug nuts on my Leatherback should be torqued to 55 ft. lbs., does this sound correct? Thanks Ray A
Ray A from PA is offline   Reply With Quote
Old 05-09-2010, 07:01 PM   #2
Louis
Default Re: Lug Nut Torque
55 ft. lbs. does sound right, but in the 30's and 40's who had a torque wrench?
I use a reg. ole 4 way lug nut wrench,.. or you could use the hand crank wrench.
you'll know when it's tight enough.
Louis is offline   Reply With Quote
Old 05-09-2010, 07:23 PM   #3
Bruce,Upstate NY
You could tighten them with the crank supplied for the purpose and then check with a torque wrench to see what you have. I've always used 50#. If paint is on the friction surface, recheck after using a while.
Bruce,Upstate NY is offline   Reply With Quote
