05-17-2024, 07:08 AM | #1 |
40 Sedan Deluxe Speaker install - No studs?
Hi, I have a 40 Sedan Deluxe and I see the 5 x 7 speaker on ClassicCarStereos, and I go behind my dash, and there is no place to bolt the speaker in?
Am I missing something? How does one put a speaker in the speaker grille area? |
05-17-2024, 07:38 AM | #2 | |
Re: 40 Sedan Deluxe Speaker install - No studs?
As you are attempting to modify your car, well, it's up to you to figure out how to do so.
05-17-2024, 07:47 AM | #3 |
Ooooh, ok. So the modern radios dont have that. Ok. Hmmm. Interesting. Thanks!
05-17-2024, 08:56 AM | #4 |
Robert: Don 't make the mistake of drilling any holes in your dash for the speaker. You may consider mounting the speaker somewhere else. Perhaps under the glove box.
05-17-2024, 09:43 AM | #5 |
That sounds like a good idea Jim.
05-17-2024, 09:47 AM | #6 |
05-17-2024, 11:45 AM | #7 |
There is one that goes over the radio knob posts and hangs the speaker in the "spot". I could also easily make one out of strap metal looking at this.
05-18-2024, 10:36 AM | #8 |
Mount a pair of speakers, one in each kick panel. That's where I have mine and mounted the radio in the glove box without modifying the dash.
