Old 05-05-2024, 03:31 PM   #1
dorvedahl47pu
dorvedahl47pu's Avatar
Default Flathead Machine Shop-Utah
Good afternoon,
Does anyone know of a reputable machine shop in Utah that will do work on flatheads?
Thanks.
Dale
dorvedahl47pu is offline   Reply With Quote
Old 05-05-2024, 03:40 PM   #2
TJ
TJ's Avatar
Default Re: Flathead Machine Shop-Utah
If you are a V-8 Club member check your roster for people in your area and I'm sure they can refer you to a reputable shop. It's one of the advantages of belonging to the club.
Old 05-06-2024, 10:12 AM   #3
Elmo Rodge
Elmo Rodge's Avatar
I know of one around Provo. I'll have to look later for the information.
Wayno
Life is not a spectator sport.
Elmo Rodge is offline   Reply With Quote
Old 05-06-2024, 05:33 PM   #4
dorvedahl47pu
Wayno
Thank you. That would be great!
Old 05-06-2024, 09:23 PM   #5
Elmo Rodge
Elmo Rodge's Avatar
Dale, it is C&T Automotive in Orem. They did the machine work on my race motor. I was very happy with them.
Wayno
Old 05-07-2024, 09:13 PM   #6
dorvedahl47pu
Thanks Wayno!
Old 05-11-2024, 01:51 PM   #7
dorvedahl47pu
Turns out C&T isn't accepting any additional flathead work....
Old 05-11-2024, 07:41 PM   #8
deuce_roadster
deuce_roadster's Avatar
Probably the old timers that knew flatheads and worked there have retired (or worse).
Old 05-12-2024, 10:15 AM   #9
dorvedahl47pu
They said they have a guy but he is swamped.....
Old 05-13-2024, 12:27 PM   #10
Pete
Originally Posted by dorvedahl47pu View Post
Good afternoon,
Thanks.
Dale
I sent you a PM but I guess it did not go through.
Try Salt City Speed Shop in Layton.
(385) 777-1934
Pete
Old 05-13-2024, 02:02 PM   #11
Ronnieroadster
Ronnieroadster's Avatar
(385) 777-1934
Pete
From what I know they don't build flatheads.
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 05-13-2024, 06:14 PM   #12
dorvedahl47pu
Well, they say they do more flatheads than anyone else in Utah. I'll see if they can h elp me out. Thanks everyone.
Old 05-14-2024, 03:36 PM   #13
Ronnieroadster
I believe they send them out let us know what you find out.
