05-07-2024, 05:47 PM | #1 |
Disc brakes for wide-5 drums
I want to keep the wide-5s on my '37. Anyone aware of a source for a disc conversion? Currently running 46-48 F/M hydraulic set-up. Any help appreciated. Thanks!
05-07-2024, 06:17 PM | #2 |
Re: Disc brakes for wide-5 drums
It might not be very practical to do a set up like that for the Ford wide 5. It could be done with adapters but it would change back spacing on the wheels. The adapters would have to clear the calipers too.
05-07-2024, 06:39 PM | #3 |
Since the wide five pattern was and still is used for stock car racing disk brakes systems are readily available. One example Winters Performance In Pennsylvania has wide five disk brake options but its going to be pricey.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH Last edited by Ronnieroadster; 05-07-2024 at 06:48 PM. |
05-07-2024, 07:28 PM | #4 |
Thanks, Ronnieroadster. Anyone know of any other sources?
05-07-2024, 10:39 PM | #5 |
Circle trackers also use 5/8th" lug studs. Usually will fit Ford original wheels tho. Newc
05-08-2024, 04:28 AM | #6 |
05-08-2024, 07:39 AM | #7 |
Thanks, Deucelover. Speedway looks a lot better $$$$-wise than Winters!!
05-08-2024, 04:42 PM | #8 |
I know you said that you wanted to go to disc brakes, but have you considered using Lincoln Zephyr brakes. I installed '40 Ford brakes on my '37 1/2 ton, and I never felt confident in the ability to get the truck stopped in an emergency situation. I installed re-pop LZ brakes on the front and the difference is nothing short of amazing.
Tom |
05-08-2024, 06:17 PM | #9 | |
This is true IF you use the BOLING BROTHERS' repro parts - NOT the "SPEEDWAY MOTORS" parts. There have been several problems with the SPEEDWAY drums being out of round. The BOLING BROTHERS' drums are the 'nuts'! Plus, you can still use your '37 drum/hub package with the Boling Brothers' backing plate assembly if you wish. You DON'T need disc brakes on that car!!! Coop . |
05-08-2024, 06:24 PM | #10 |
I seem to remember that someone on the H.A.M.B. was making special wide-5 hubs for just this purpose. I did a quick look-see and couldn't find it. Maybe someone else here has a better memory.
05-08-2024, 06:27 PM | #11 | |
That was POSSIBLY a piece made for tire/wheel balancing purposes. Coop . |
05-08-2024, 06:29 PM | #12 | |
I believe he quit because of high cost and low demand. (I'm an expert on that after my condenser and Tachometer Driver debacles.) Last edited by tubman; 05-08-2024 at 06:35 PM. |
05-08-2024, 06:53 PM | #13 |
Autocross = Disc Brakes
Non Autocross = Boiling Bros. |
05-09-2024, 08:41 AM | #14 |
Searched Boling Bros. Got Vintage Parts AZ. They are showing only non-wide-5 drums. No hubs. What's the magic with the repro L-Z set-up? Do you need everything: backing plates, shoe ass'y and hub/drums? Or just one or the other? Got the advice on Speedway. Tks.
05-09-2024, 08:57 AM | #15 |
Please ignore my last post. I just remembered something about an ad for L-Z brakes in the V8 Times. Pg 109 of the March/April issue has the Boling Bros. info. Looks like the set-up is for 1940+ style wheels. So back to my search for a wide-5 solution. I'll call them to see if they can help. Meantime, any other sources? Thanks for everyone's input.
05-09-2024, 09:22 AM | #16 |
Get these from Speedway and have the 5.5 pattern put in them
https://www.speedwaymotors.com/Speed...nch,29179.html |
05-09-2024, 10:10 AM | #17 |
Boling, M/T and Riley websites no longer in operation. I'll phone them today and report. Tks again.
05-09-2024, 10:42 AM | #18 | |
They may fit, but measure before you buy. Or maybe, get a disk brake setup that matches those adapters (5 on 4 3/4"). |
05-09-2024, 11:20 AM | #19 |
I should have included more info in my original post regarding LZ brakes. I used Boling Bros backing plates and the appropriate width brake shoe, they offer both 1 3/4" and 2" shoes. They produce quality parts, you won't be disappointed.
Tom |
05-09-2024, 11:27 AM | #20 | |
