04-22-2024, 07:03 AM | #1 |
Grease fitting
Need to replace fittings on front spindle, I'll need to drill and tap them what size drill and tap should I use.
TIA Dick |
04-22-2024, 08:20 AM | #2 | |
Re: Grease fitting
If they are press in then there are special drivers available from the vendors to help you install them without deforming them. Also, when you install new bushings, be sure the holes in the bushings line up with the holes in the spindle so the grease has somewhere to go.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan Last edited by JayJay; 04-22-2024 at 08:28 AM. |
04-22-2024, 08:56 AM | #3 |
Re: Grease fitting
Is an "r" drill 1/8"?
04-22-2024, 09:36 AM | #4 |
Re: Grease fitting
R is .339
The spindle grease fittings are press in. Last edited by Bob C; 04-22-2024 at 09:45 AM. |
04-22-2024, 10:07 AM | #5 |
Re: Grease fitting
No, 1/8" pipe thread tap is quite a bit larger than 1/8" diameter as BobC suggests.
Someone correct me if I'm mistaken, but aren't the press-in fittings 5/16" diameter hole? But you need to be very careful, if you oversize the hole by wobbling the drill then the press-in fittings won't stay pressed in. Best to carefully remove the old fittings and then press new ones in without drilling. If the holes get so chowdered that the press-in fittings won't stay in then you can overdrill with the R drill and thread for screw-in fittings.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan Last edited by JayJay; 04-22-2024 at 01:22 PM. |
04-22-2024, 05:25 PM | #6 |
Re: Grease fitting
