Old 04-07-2024, 09:54 PM   #1
fordor41
fordor41's Avatar
Default 2 sp fordomatic
well decided I'm not pulling the Fordomatic out for about the 20th time to solve the L to H delay in shifting problem. Found out if I run the car in reverse with e brake on, for about 5-8 min to get it warm, it shifts like a charm
fordor41 is offline   Reply With Quote
Old 04-08-2024, 07:46 AM   #2
pistonbroke
Default Re: 2 sp fordomatic
I found if I put it in first and drove mine for about two blocks it would find second and third much better for the rest of the drive. But its just a band aid fix, either your seals are worn or your clutch packs. Maybe both are . What you're doing is decreasing the clearances with heat expansion. Tim
Old 04-08-2024, 10:28 AM   #3
Newc
Newc's Avatar
My problem was the 1st/reverse band worn out. Newc
Old 04-10-2024, 09:22 AM   #4
richard crow
put a cup of dot 3 brake fluid in it
richard crow is offline   Reply With Quote
