Old 04-01-2024, 06:36 PM   #1
spdway1
spdway1's Avatar
Default How tight should the...
Hello All,
How tight should the drag link and tie rod end plug be? How much play if any?
Thank you.
spdway1 is offline   Reply With Quote
Old 04-01-2024, 06:59 PM   #2
ModelA29
ModelA29's Avatar
Default Re: How tight should the...
Zero play - but loose enough you don't squeeze the grease out and cause wear.
ModelA29 is online now   Reply With Quote
Old 04-01-2024, 07:00 PM   #3
Bob from Northport
Bob from Northport's Avatar
Just tight enough to get the cotter pins in to secure the plugs
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 04-01-2024, 08:31 PM   #4
acchaplin
I read somewhere on the BARN that the 'nut' is to be tightened all the way down, then back it off one full turn.
acchaplin is offline   Reply With Quote
Old 04-01-2024, 08:52 PM   #5
Bigsnapper43
Some where in my reading 25 foot pounds came to light.
Bigsnapper43 is offline   Reply With Quote
Old 04-02-2024, 06:59 AM   #6
Kurt in NJ
Kurt in NJ's Avatar
If the balls are not new and round the adjustments should be made turned to lock then adjusted to coil bind of the springs then backed off to cotter hole.
There will be many opinions and some reproduction parts are not to original specifications
Old 04-02-2024, 07:36 AM   #7
Bob Bidonde
Bob Bidonde's Avatar
This slide will help you:
File Type: jpg Drag Link & Tie Rods End Plug Adjsutment 198kb.jpg (66.0 KB, 167 views)
Bob Bidonde
Old 04-02-2024, 08:11 AM   #8
Kurt in NJ
Kurt in NJ's Avatar
Bob, where in era literature does that specification come from?
Old 04-02-2024, 09:31 AM   #9
Y-Blockhead
Y-Blockhead's Avatar
Good question, I would like to know also. The only time I seen that was in Les Andrew's book.
Old 04-02-2024, 10:30 AM   #10
katy
katy's Avatar
Not sure if this applies to Model As or not, (this is the only place I ever found anything about adjusting the drag link ends) but my 1965 Ford Truck shop manual says: "Tighten the threaded plug in the end of the socket until the spring is fully compressed (ball seat bottoms on spring seat). Then back off the plug approximately 1 turn to the point where the slot in the plug lines up with the cotter pin holes in the drag link. Install a new cotter pin through the end of the drag link to lock the plug
Old 04-02-2024, 10:53 AM   #11
rotorwrench
rotorwrench's Avatar
This is where the need for a spring of the same wire size, free length, and spring rate is optimal. Reproduction parts don't always match the OEM parts. The little slide that Bob posted on #7 is likely very close to bottoming the spring and backing it off a turn. The main thing is that the spring is stiff and near coil bind but not bound. It needs just a bit to absorb shock loads from hitting bumps and such. These type of joints weren't the best but they do function well enough when wear is minimal. Worn out balls & sockets should be repaired or replaced just like a worn out modern ball type joint.
Old 04-03-2024, 06:36 AM   #12
nkaminar
nkaminar's Avatar
I just put the Teflon pads in my car and it steers a little easier, see https://www.snydersantiqueauto.com/p...7730&cat=41738
The new pads will not fix out of round balls. In my opinion, the Teflon pads have the main advantage of not wearing the balls.
If you tighten, or adjust the pads in the tie bar, check the toe in alignment. I had about 1/8 toe out after putting the new pads in my car. See page 375 of the Service Bulletins.
Old 04-03-2024, 10:42 AM   #13
Joe K
Joe K's Avatar
Ditto on the Teflon pads/cups. HOWEVER, their use is akin to the rubber wishbone ball cover - don't expect a tremendous life and keep an eye out for slop or "mushrooming."
Joe K
Shudda kept the horse.
Old 04-03-2024, 03:06 PM   #14
nkaminar
nkaminar's Avatar
Delrin may be a better choice for the pads as it will wear a lot better and not deform, but still is a slick plastic and softer than the steel balls.
Old 04-04-2024, 05:30 PM   #15
gdmn852
gdmn852's Avatar
Hello, as per last 3 posts , that was my reasoning also for using the plastic inserts, easier than replacement of steering arms ,again.
gdmn852 is offline   Reply With Quote
Old 04-04-2024, 10:54 PM   #16
spdway1
spdway1's Avatar
Thanks for getting off-topic.
Old 04-05-2024, 06:10 AM   #17
nkaminar
nkaminar's Avatar
You are welcome. I think others have covered the subject of how tight the pads should be. If all the parts are good you can screw the plugs in until the cotter pins can be inserted. The pads should be tight but not too binding. Some judgement is required. If the parts are worn out or in doubt then they need to be replaced. Just remember if you replace or adjust the tie rod to check the toe in after you are done. The instructions on Snyder's show how the parts should be used for the drag link and this is the same for the steel pads. See https://www.snydersantiqueauto.com/c...0New%20Von.pdf.
Old 04-05-2024, 09:34 AM   #18
katy
katy's Avatar
Anyone know what grade of teflon is used to make the Teflon pads/cups?
http://www.standard-ptfe.com/propert...Steel%20Filled
Old 04-07-2024, 09:32 AM   #19
Bob Bidonde
I researched all of the Ford Service Bulletins 1928 through 1942 and there is no quantitative instruction about tightening the drag link and tie rod end plugs. I use the 25% spring compression technique because it makes the most technical sense to me. All I did find was qualitative text indicating the drag link and tie rod need to be able to rotate, and not be loose (no play).
Bob Bidonde
Old 04-07-2024, 08:50 PM   #20
spdway1
spdway1's Avatar
Thank you for your efforts, Bob. I will be tackling it tomorrow afternoon, What eclipse?
Thanks again,
Don Jr
