03-27-2024, 05:30 PM | #1 |
Location: Daniel Island,SouthCarolina/Knoxville, Tennessee/Sanibel Island,Florida
distributor swap out question
My 12v 1931 Tudor had a distributor that lost spark.
I swapped it out with a spare distributor, and have spark again, (cranking with the plugs removed) but the distributor cam lock nut on the spare distributor won't budge and am gonna have to drill it out. I would like to see if the engine will start with the spare distributor in place before removing it to replace the distributor shaft. In essence, I can't check the timing with the replacement distributor at this point. The spare distributor came out of a running car. Is it reasonable to think the car might start with the engine at TDC and rotor at the #1 cylinder with out actually checking the timing since the now in-place distributor came out of a running car? Or any concerns in trying? |
03-27-2024, 06:23 PM | #2 |
Re: distributor swap out question
The timing could be anywhere. The chances of it being close enough to run the engine (without damage) is very slim. I'd either fix the distributor that came out (what was the problem) or get the screw out, even if you have to buy a new shaft and screw for it.
I'm part of the only ever generation with an analogue childhood and a digital adulthood. Last edited by Synchro909; 03-27-2024 at 08:03 PM. |
03-27-2024, 06:35 PM | #3 |
You say are running 12V. Did you put in a ballast resistor or change the coil? You may have fried your condenser or your points may be pitted badly. Just a place to start.
03-27-2024, 06:58 PM | #4 |
Put a new condenser in the original dizzy that caused the car to lose spark. No change.
Put in back up dizzy and now have spark with plugs removed when cranking, just can't reset timing due to frozen dizzy lock cam screw with this dizzy. |
03-27-2024, 08:04 PM | #5 | |
www.whidbeymodelaclub.com |
03-27-2024, 08:45 PM | #6 |
03-27-2024, 08:50 PM | #7 |
It is messed up already, try an impact screw remover that you hit with a hammer.
03-27-2024, 09:53 PM | #8 |
I would not suggest an impact screw driver that you hit with a hammer- the cast iron casting will probably crack and you will then have nothing but scrap.
03-28-2024, 10:40 AM | #9 |
Did not think that through, do not hit
03-28-2024, 11:14 AM | #10 |
Keep it simple.
Eye ball it. Crank engine over by hand until timing pin goes into the dimple, then look at where the rotor is pointing and at the points. If the rotor is in the proper quadrant the points need to be just ready to start opening.
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 03-28-2024 at 11:15 AM. Reason: Addition |
03-28-2024, 12:17 PM | #11 |
My money would be on fixing the original distributor. They just don't quit for no reason. Try a different capacitor (condensor) first as this is the simplest. Check to see that there are no shorts to ground by using your ohm meter. Put some new points in and adjust them correctly. You can test the distributor out of the car by using your ohm meter.
03-28-2024, 12:25 PM | #12 |
There is one more possible ghost problem not seen often but yes it shows up. You could have an intermittent short in the ignition cable. Perhaps when you moved the cable to reconnect the temporary distributor the wires aligned for voltage transmission. For those following it is not a bad idea to be suspect of the ignition cable when spark or voltage is not present.
03-28-2024, 12:48 PM | #13 |
I have had some success in the past removing distributor cam screws as follows:
03-28-2024, 01:54 PM | #14 | |
Joe K
Shudda kept the horse. |
03-28-2024, 03:18 PM | #15 |
I have a bottle of powdered tungsten that I use in times like this. A tiny amount of the screwdriver blade and it won't slip. As a substitute, maybe some valve grinding paste?
