03-21-2024, 06:22 PM | #21 |
Re: 276 stroker from 35 years of parts
From the condition of the three pictured choices, and keeping the intended use in mind, I'd go with the 8BA.
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302 |
03-21-2024, 09:01 PM | #22 |
This brings to mind the issues of new lifters on a used cam. This is generally considered to be OK as long as the cam is in good shape. In the final analysis, you can try anything, but using mixed parts can sometimes end up in not a good way.
03-22-2024, 09:55 PM | #23 |
'Repair Manual'
'Ford and Mercury V8 Engines 78-81A-59A series 1937 to 1948 Pass. Cars 1937 to 1947 Trucks' 3666-48D Printed June 18. 1948 by Ford Motor Company, lists the fits and tolerances, along with their recomended wear limits when repairing their V8 using various combinations of used parts in conjunction with new parts. This book was intended for use by Ford service mechanics in their facility. I plan to use this book as my reference, as I have many times in the past when dealing with using new parts alongside old parts. I will venture that many engines today are built with brand new shiney parts from the the major supply houses that might very well have come in from all over the globe. There is always the chance that the materials and workmanship might not be as good as what Henry specified, so for me, I prefer a measured and inspected used Ford part.(not to mention I have buckets of them). When asked about valves, Les told me the Ford valves are excellent and what to look for when I dump out my 2 coffee cans full. I still have a lot of questions about oil pumps, truck oil pans, truck water pumps, tin foil balls, original Ford lifters and grinding stems, cleaning out the crank oil passages, cam gears (I have seven), crank gears, baffles, etc. I'm quite set on a stock merc or 8ba cam, though many have tried to sway me into being a 'hot rodder', I happily remain a 'brown shoed square'. Your's truly, GB
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
03-23-2024, 12:22 PM | #24 |
It also has to do with spring pressure. If you're running a stock cam, you only need about 45 -50 lbs (max) of spring pressure . . . so that tends to be a bit more forgiving when using older lifters. BUT, you want to check the bottoms of the lifters - they should have a very slight convex "crown" on them. If not, then you might want to get them resurfaced.
03-23-2024, 01:41 PM | #25 |
Thanks, I'm still a bit up in the air about lifters. I have 2 complete sets of old Johnsons. One from a cracked block tear down and one set from a swap meet. I ended up with 2 of the same sioux valve face surfacers (both were given to me) I have been swapping parts around and will end up with a really nice one. Been experimenting with the stem grinding and it is very satisfying. I can see this becoming like a 'which cam?' thread, so in the end I alone will have to decide. I have been out in the shop this morning messing with cleaning up cams on my lathe. Ford's book says to discard a cam with journals less than 1.7955. My new inserted bearings are 1.799. Right now I am of course walking the line between nicely polished journals and too small. Lastly, what does anyone know about an 8RT cam? NOS Ford in cosmoline are available for less than 200 bucks. (military?) Very little written about them on the web, but most say they think it's same as 8BA.
03-23-2024, 03:03 PM | #26 |
Rick |
03-23-2024, 03:50 PM | #27 |
Now that you have the cam selected ( I like the EAB cam) find a set of EAB heads and mill for 40/45 piston to head clearance, Lot of things tot hink o f here. Good luck
Gramps |
03-23-2024, 04:27 PM | #28 |
Quote from Gary's initial post:
" I have a lot of preferences already and my desired end result may very well be miles away from what a 'normal' V8er is looking for in his build. 98% of my driving will be under 40 mph on a very hilly 58 square mile island. This woodie has very little to do with overdrive, high speed, hot cams, or any speed equipment for that matter. It has everything to do with serviceability, low end torque for the hills, smoooooth idle, and as always, that elusive 'built on a shoestring' budget." Based on that, any cam other than stock would (in my opinion and experience) be a waste and quite possibly detrimental. An 8BA or 8RT will run beautifully in that application. Getting piston to head clearance as close to .040" as I could?....I'd be all about getting that done. Terry
03-23-2024, 05:43 PM | #29 | |
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) Last edited by GB SISSON; 03-23-2024 at 05:55 PM. |
03-23-2024, 06:11 PM | #30 |
I suspect the 8RT cam is either the same as the 8BA cam, or is the older 37-48 grind. I would check the 8BA and the EAB cams for condition and if either are good use them first, with preference on the 8BA cam. No need to spend another $200 you don't need (that will be used for water pumps, gaskets, or some other necessity). Post the journal diameters and we can keep offering opinions. You definitely want good cam to bearing clearances as that directly affects engine oil pressure.
03-23-2024, 06:51 PM | #31 |
And I watch my oil pressure like a hawk. Ask my kids... On long driving vacations (every family car we owned had high mileage), my mood would revolve around the oil pressure I was seeing on the aftermarket gauge. Here are some photos from this morning's adventure in cam cleaning. I mic'd the heel/toe dimension before and after sanding with 600/800/1000/1200 wet dry with MMO for lubricant. This gave a surface I could live with for the lobes, The journals took a lot less work. I downshifted the lathe into back gear on the lowest of 4 belt speeds and was at 35 rpm. The journals remained constant at 1.795-1.796. But get this..... Using my dial indicator with cam in the lathe(not running) I found .341 gross lift on the ones I had not surfaced, and gross lift on the two I completed to my satisfaction I had a gross lift of .338 and .339. I knew my method would take more off the toe as the oak splint exerted the greatest spring pressure at that point. Must be why someone altered the EA designation. Anybody want this thing? Unfortunately the other 2 cams have similar sized journals. I already have gaskets, can I buy that nos 8rt cam?
03-23-2024, 08:13 PM | #32 |
It don’t matter where you live……..I’m calling that Yankee Ingenuity! …….Mark
03-23-2024, 08:17 PM | #33 | |
03-23-2024, 09:29 PM | #34 | |
03-23-2024, 09:33 PM | #35 | |
Use it up, Wear it out, Make it do, Or do without He claimed it was the true New England yankee creed.
03-23-2024, 10:39 PM | #36 |
Sounds like the same thing my Dutch Dad told me
03-24-2024, 12:04 AM | #37 |
I now see that someone got the last one of those cosmoline coated camshafts this morning. Oh wait, it was me, earlier today. And flatjack, I don't know if it has '8RT' markings on the camshaft itself. I guess we'll find out. https://www.ebay.com/itm/393197818167
03-24-2024, 12:28 AM | #38 |
Thanks Ron, I dug out a couple sets of those from my stack last winter. I set aside the best looking pair on a dedicated shelf where I have been stockpiling everything I need for this engine. It's starting to get exciting.
03-24-2024, 12:29 AM | #39 | |
03-24-2024, 12:33 AM | #40 |
