03-07-2024, 07:41 AM | #1 |
Crestliner Horn Ring Removal
I just picked up a 50 Custom, and it has a crestliner steering wheel, which is pretty nifty. The thin parts of the ring are broken off, but still cool. Honks like a mother effer.
I've searched for a decent while, but noone really has the "yes this is correct" answer on removal. To remove the horn ring on a crestliner wheel, is it the traditional 3 tab lock style, push-in and turn CCW? The horn pretty much stays near bottom so doesn't feel like a spring is there, and I just want to get some better insight before I snap the ring and someone tells me there was a screw in it from the back of something. If anyone has a picture of their horn ring removed, that would also be a huge help. Thanks in advance. |
03-07-2024, 10:14 AM | #2 |
Re: Crestliner Horn Ring Removal
Yes, push down and rotate CCW.
Ken
https://www.nirgv8.org |
03-07-2024, 04:04 PM | #3 |
There are two screws holding the ring and the center button can be lifted off. The screws are located at 3 and 9 o,clock with the wheel straight like your picture is. If the horn works I wouldn't remove it. Its not easy to work on. the foam ring is no longer available.
03-08-2024, 07:08 AM | #4 |
