Old 12-15-2023, 12:37 PM   #1
pjdeb
pjdeb's Avatar
Default Crank end play
I have 023" end play in the crank as measured between the end of the block and the crank flange. What is this going to do to the operation of the magneto?
I was undecided about putting in a new magneto or running off battery.
Thanks in advance for comments. It is a 1923 coupe.
pjdeb is offline   Reply With Quote
Old 12-15-2023, 01:06 PM   #2
Dan McEachern
Default Re: Crank end play
Consider taking the cap to a rebabbitting shop and have them build up the thrust surface and remachine it to give you .003-.004" endplay. You don't need a replacement cap, just build up the thrust. Your mag will not run very well with that much end play.
Dan McEachern is offline   Reply With Quote
Old 12-20-2023, 03:53 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
I have that much end play, had a magneto that only made 3 volts, did the on car recharge process with 3 12V batteries and heavy wire, now have 9 volts hand cranking, easy hand crank starting on magneto.
there was a big thunk as the power was applied as it shifted the crankshaft
