03-24-2023, 07:44 PM | #1 |
Horn relay
Years ago I removed a relay similar to the one Brattons sells (red,yellow and black wires). I saved the relay and now I want to use it again but I can’t find the instructions. Can anyone help?.
Thanks, Ian |
03-24-2023, 08:54 PM | #2 |
Re: Horn relay
Here's a link to Bratton's instructions. https://www.brattons.com/PDFs/20040%...%20DIAGRAM.pdf
03-25-2023, 07:26 AM | #3 |
Re: Horn relay
Ian, Did you get hit with the bad weather?
If the instructions that Bob linked to don't work, use and ohm meter. Two wires will be open and those hook from ground to the side of the horn not coming from the battery. The other two wires will have some small resistance and those will be the activating coil. Hook one to the battery and one to the horn switch. In both cases polarity does not matter. Another way to hook it up is for the two wires that are open, one to the battery and the other to ether side of the horn terminals. The other side of the horn terminal will then go to ground. That way the horn does not have a constant hot wire.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 03-25-2023 at 07:32 AM. |
03-27-2023, 06:55 AM | #4 |
Re: Horn relay
