05-28-2010, 09:26 AM | #21 |
Re: Frustrating Oil Leak
Thanks for the feedback!!
Norm |
05-28-2010, 11:08 AM | #22 |
Try installing a PCV Valve. Relieving the pressure inside the engine might effect the oil leak. My 59 A/B leaks not! I installed a full-circle lip-seal on the front of the crank and a PVC tappled into the underside of the intake manifold. The PCV was from an early Mustang 6 cylinder and has pipe treads on one end, so it screws right into place. No hoses!
I use fluid grease, NLGI #000 with MoS2 (Moly) in the gearbox and steering gearbox, and they don't leak either. Rocketsled |
10-14-2013, 08:59 PM | #23 |
An oil leak coming out of the slot at the bottom of the bell housing could also mean your trans front seal is worn as I found out when I swapped a 3 speed for an overdrive unit.
10-14-2013, 10:05 PM | #24 |
It has been so long since I made this post that I forgot what I did to solve the problem. I looked through my records and found a receipt for an oil pump drive cover from Baxter Ford Parts. Then I looked back at my engine photos and saw the culprit--a brass screw extending beyond the engine surface so that the old cover could not seal the area and was warped in the process of tightening. I filed off the extruding screw head, inserted the gasket and new cover and "presto" no more leaks (well maybe a couple of drops once in awhile). I hope my pictures come through!
08-23-2014, 04:34 AM | #25 |
good to hear, I hope after this fact the oil flow is remedied/finger cross to you
12-21-2022, 08:34 AM | #26 |
12-21-2022, 11:18 AM | #27 |
does a 59-ab use a slinger rear main ? If so is that the problem ?
12-22-2022, 02:27 AM | #28 |
The PVC advice is spot on. I welded up the 59A style pan breather with a pipe plug, and routed that opening to a PVC- No more leaks- Negative crankcase pressure!. Newc
