Old 06-06-2022, 10:09 AM   #1
EZLIFE
Default WD40 as hand cleaner
Wondering if I am the only one that uses WD40 for cleaning the grease off my hands?
EZLIFE is offline   Reply With Quote
Old 06-06-2022, 10:11 AM   #2
bruceincam
bruceincam's Avatar
Default Re: WD40 as hand cleaner
The only one that I know of -----------
bruceincam is offline   Reply With Quote
Old 06-06-2022, 10:21 AM   #3
katy
katy's Avatar
I use sawdust, then soap and water.
Old 06-06-2022, 10:40 AM   #4
Oldbluoval
Oldbluoval's Avatar
Go-jo or such
Then lava soap
I think wd-40 stinks and stays with you
I’ve also started using rubber gloves alot especially when into parts cleaners
Old 06-06-2022, 10:50 AM   #5
Jim Brierley
I use borax and dish washing soap.
BTW, WD-40 makes a good under arm deodorant too! :-)
Old 06-06-2022, 11:01 AM   #6
Ruth
I don't use WD40 for much of anything.
Ruth
Old 06-06-2022, 11:03 AM   #7
brunoboy
I use dish washing liquid and a worn out scotch brite pad.
brunoboy is offline   Reply With Quote
Old 06-06-2022, 11:03 AM   #8
Badpuppy
Yeah, you're the only one.
Old 06-06-2022, 11:10 AM   #9
Big hammer
I’ve used wd-40 for cleaning greasy hands, it also helps arthritic hands! Mostly use it for cleaning bugs and tar off of paint
get a bigger hammer tap done
Old 06-06-2022, 11:59 AM   #10
51504bat
51504bat's Avatar
This:
Old 06-06-2022, 01:04 PM   #11
mleder
I think that Dawn dish soap and warm water is easiest on your hands and is inexpensive , works very well especially with a small brush. Gojo is good but if you tend to use water to remove it and the dirt rather than a paper towel or a rag, sooner or later you will be needing to clean your drain as it can gum up the drainage path.
mleder is offline   Reply With Quote
Old 06-06-2022, 01:10 PM   #12
42merc
42merc's Avatar
Dawn dish soap & a scrub brush works for me.
42merc is offline   Reply With Quote
Old 06-06-2022, 01:28 PM   #13
SwampLedge
I like Tub o’Towels. Great for removing oil/grease/dirt from hands and other objects without water. I do use WD40 as a solvent when cleaning machine parts that the water-based parts cleaners struggle with.
SwampLedge is offline   Reply With Quote
Old 06-06-2022, 01:34 PM   #14
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Boraxo! Keep them mule teams moving!
Old 06-06-2022, 01:46 PM   #15
GeneBob
I have never used WD-40 BUT automatic transmission fluid works well for the worst oily grime that I have gotten into. Then clean with hand cleaner.
BTW, penetrating oils like PJ Blaster do a good job of cutting into the grime on parts before cleaning with something else. I suppose WD-40 would be similar to this.
GeneBob is offline   Reply With Quote
Old 06-06-2022, 01:54 PM   #16
Eccentric Old Guy
Eccentric Old Guy's Avatar
I can't help to think those things are pretty good at penetrating your skin, too.....from there, who knows where the chemicals go?
eog
1928 closed cab pickup. All black, no bling or add-on shiny stuff. Just a simple working man's truck.
Eccentric Old Guy is offline   Reply With Quote
Old 06-06-2022, 02:18 PM   #17
ursus
eog
Let's see, liver, kidneys, lungs, nervous system, etc,. etc., ...
Old 06-06-2022, 03:07 PM   #18
Aretino
Aretino's Avatar
I buy it by the gallon. Hand cleaner- yes! Tar remover-yes. Pentrating oil-yes. Displaces moisture and leaves a protective film.
Aretino is offline   Reply With Quote
Old 06-06-2022, 03:21 PM   #19
Oldbluoval
Oldbluoval's Avatar
“BTW, penetrating oils like PJ Blaster do a good job of cutting into the grime on parts before cleaning with something else. I suppose WD-40 would be similar to this.”
I use Eazy Off oven cleaner a lot
Especially on things like latches and regulators
Spray on put in the sun, wash off in 30 minutes or so.
Old 06-06-2022, 04:29 PM   #20
Ruth
If WD40 does what it is supposed to do, displace water, what is it doing to the moisture in your skin?
Ruth
