11-12-2021, 10:21 PM | #1 |
Oil Drain Tube Thread Size
The hole in the rear bearing cap is 1/8-27 NPT. The tubes sold by the vendors are 3/8-32 UNF..
Should they be the same? |
11-14-2021, 11:29 AM | #2 |
Re: Oil Drain Tube Thread Size
Ford used two different sizes of these tubes. The one the vendors have is the later version meant to cure a problem with clogging, etc. You may have to search for a used one or drill and tap the cap for the larger tube.
11-14-2021, 12:10 PM | #3 |
Berts has both sizes of drain tubes...
https://modelastore.com/index.php?ro...&category_id=0 NOTE: Most main caps I see have a SMALL tack weld so it will not fall off. You have to be sure when gas welding or brazing not to melt the babbit in the main cap. Maybe an engine builder will comment on whether Mig or Tig is better. Last edited by Benson; 11-14-2021 at 12:31 PM. |
11-14-2021, 04:21 PM | #4 | |
Ora at Schwalms recommended red loctite. |
11-15-2021, 01:00 PM | #5 |
Get a piece of 1/8 pipe and make your own drain tube.
05-22-2023, 10:41 PM | #6 | |
05-23-2023, 07:18 AM | #7 | ||
Steve is correct. Just for clarity, the early A-6325-AR Cap's hole was threaded 5/16-32. . |
05-24-2023, 12:04 AM | #8 |
What size were the B pipes?
