11-01-2020, 09:27 PM | #1 |
Speedometer 1950 F3
I drove my truck today for the first time in over 30 years! It drove great! But the speedometer was bouncing all over the place and making a loud vibration noise. I remember it not be reliable before so didn't get to concerned about that. Finally it stuck at 0 and the needle is all catiwaumpus. I assume something came apart inside. Is there any repair to them? Any idea where I could find a new or used replacement? Not looking forward to taking that out...
Sent from my SM-G973U using Tapatalk |
11-01-2020, 10:09 PM | #2 |
Re: Speedometer 1950 F3
Why not take the cable out and see if it was dry and broke.
11-02-2020, 08:00 AM | #3 |
11-02-2020, 08:02 AM | #4 |
Adding a couple pictures
11-02-2020, 08:14 AM | #5 |
definitely broke in the speedometer, may be easier/cheaper to find another than repair
11-02-2020, 08:24 AM | #6 |
Mike Last edited by Black Fifty; 11-02-2020 at 10:02 AM. Reason: add content |
11-03-2020, 09:02 AM | #7 |
My old eyes see the needle shaft either broke or the jewel bearing failed usually caused
by the cable and casing dry that makes the needle violently bouncing. those are on ebay all the time. cheaper to replace than to send it out and swap the odometer which is easy. Nice one on ebay right now for cheap....sam |
12-27-2020, 09:17 AM | #8 |
12-27-2020, 10:39 AM | #9 |
The cable has a threaded collar on both ends. Undo them and pull the cable out.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
12-27-2020, 10:45 AM | #10 |
Every speedo cable I have pulled out is from the speedo end. I usually didn't disconnect the transmission end.
03-06-2021, 10:21 PM | #11 |
I tried pulling the cable out today but it didn't want to come. I didn't want to pull too hard and break something. I'm pulling on the speedo end I haven't tried taking the other end off yet. Is there something holding it in place?
03-06-2021, 10:25 PM | #12 |
Yes, the threaded collar.
03-06-2021, 10:42 PM | #13 |
03-07-2021, 07:16 PM | #14 |
Get in touch with Rusty at speedometer services, he may be able to help you get the cable out and can probably repair the speedometer. HRP
https://www.speedoservice.com/
‘When one door closes, another opens. But we often look so regretfully upon the closed door that we don’t see the one which has opened for us.’ Alexander Graham Bell |
03-07-2021, 07:55 PM | #15 |
The cable just pulled out of my 49. My speedo did the same thing, some screws fell out. Just cleaned things and put it back together.
"whatever works!" |
03-08-2021, 06:36 AM | #16 | |
03-08-2021, 09:00 AM | #17 |
it looks like the shift is damage will need to be repaired or replaced. papanick
03-08-2021, 02:55 PM | #18 |
The inner cable pulls out from the trans end.
'52 F-1, EAB flathead |
03-08-2021, 10:39 PM | #19 | |
