10-27-2020, 10:13 AM | #1 |
AA 1930 king pins bushings needed
Looking for source for set of AA 1930 king pins and bushings
Thanks |
10-27-2020, 11:03 AM | #2 |
Re: AA 1930 king pins bushings needed
Good Morning...You might try Arizona Model A...Sammy Guthrie...480-782-0266. He might have good used ones...or NOS...Ernie in Arizona
10-27-2020, 11:18 AM | #3 |
Snyders has the bushings, the pins a little harder, nos if you can find them.
10-27-2020, 02:50 PM | #4 |
I would call Steve ar Berts.
10-27-2020, 03:14 PM | #5 |
Many times it is only the bushings that are needed.
10-27-2020, 08:28 PM | #6 |
Red Wolf |
10-27-2020, 10:53 PM | #7 |
Dave
I have a NOS set that I can sell to you. $100 plus shipping.
Bill Cilker, Jr Unrestored 190A Victoria 45B, 160B & 189A Victoria Association President |
10-28-2020, 06:02 AM | #8 |
I found a nos set at a swap meet that I think were WWII era. They didn’t have any shims and were marked wrong as to left and right. My original thrust bearings cleaned up and looked better than the ones in the set so I used them. (They were roller bearings and the replacement were ball) I found some shims from one of the on line supply places. I used Snyder’s bushings. They were better than the WWII ones and had the correct grease grooves. Grainger has a thrust bearing that I think would work but since my original ones cleaned up good I didn’t order them. I had a local truck spring shop ream the bushings.
11-02-2020, 10:53 AM | #9 |
