06-02-2020, 07:11 AM | #1 |
Is the counter weight that.bolts onto the camshaft of 1956 t bird..a necessary part ?
While replacing timing chain ans gears...car is 1956 t bird..w 312 y block...I noticed the counter weight that bolts onto camshaft ...and the oil drip through plate that bolts on the front of the block behind cam shaft gear ..were missing.Appears those 2 parts havent been on.car for long time....had car over a year...no engine problems..
The screw hole where oil drip.should be was gunked up..but rest of block was clean.. Opinions please on whether those 2 parts are neccesary to find and replace...thank you for your time...Darris |
06-02-2020, 02:38 PM | #2 |
Re: Is the counter weight that.bolts onto the camshaft of 1956 t bird..a necessary pa
I know the voices aren't real but damn they have some good ideas! |
