11-04-2018, 05:38 PM | #1 |
leakless water pump
I have a new leakless water pump and new fan blade. I ground down the front of the water pump cause it seemed the blade was rubbing. Before installing everything seemed smooth. After installing I still have the same noise. Could it be the packing nut should be tightened? Should it be touched at all? I didn't have this problem with my old water pump that leaked water, it was quiet but very wet. :-)
Paul |
11-04-2018, 05:58 PM | #2 |
Re: leakless water pump
Try starting car without fan belt.
If still making same sound, at least you now know it’s not the generator or water pump. |
11-04-2018, 07:00 PM | #3 |
