Go Back   The Ford Barn > The Swap Meet > For Sale > Model-A
Old 09-28-2017, 11:16 AM   #1
Mark W.
Mark W.'s Avatar
Default 1929 model a ford roadster for sale
City: Stockton Springs
State: Maine
Price: $15,000
This is a very solid and rust free Model A Ford roadster with an originally installed rumbleseat. The car was a barn find from Iowa and still retains the original interior and character of a true survivor. The top was replaced in 2012 and new side curtains were custom made for her. When I had the motor rebuilt, everything was done right with new Babbitt bearings poured by George King in Connecticut and new components used throughout - if you have had any of this kind of work done you will know the expense involved...
Here is a list of work that was done:
- All brakes rebuilt
- All original shock absorbers rebuilt
- New wheel seals front & rear
- New king pins & bushings
- New aluminum fan (originals were prone to cracking & failure with ugly results)
- New motor mount springs & pads
- Fuel system cleaned, shut-off and sediment bulb rebuilt as well as the gas gage and original Zenith carburetor
- Engine rebuild including new Babbitt bearings, crank ground .020 under, re-babbitted rods, bored .060 over with new pistons, rings, and wrist pins, new stainless steel valves springs & keepers, new manifold & head studs, oil pump rebuilt, new oil pump drive gearing added, new timing gear.
- Transmission rebuilt including new sealed front and main shaft bearings, sealed cluster gear shaft, sealed reverse gear shaft, new cluster bearings, new clutch disk, and a new throw out bearing.
The car is sold with a valid Maine State warranty title. I'm located around 13 miles north of Belfast in Stockton Springs - Mark Wetherbee (207)323-8994 Please leave a message if you call, I don't always hear the phone and I usually don't answer unknown numbers...
Thanks for looking, Mark
Mark W. is offline   Reply With Quote
Old 09-28-2017, 11:16 AM   #2
Mark W.
Mark W.'s Avatar
Default Re: 1929 model a ford roadster for sale
sorry about the cell-phone pictures being up-side-down
Old 10-04-2017, 07:29 AM   #3
Mark W.
Mark W.'s Avatar
This one is still av
Old 10-10-2017, 06:05 PM   #4
Mark W.
Mark W.'s Avatar
Bump
Old 12-04-2017, 04:59 PM   #5
Mark W.
Mark W.'s Avatar
With recent interest I thought I would bump it up before the snow flies and strands it in my Barn till spring.
Old 02-28-2018, 01:54 PM   #6
Mark W.
Mark W.'s Avatar
Someone recently asked about this beautiful car, sadly I sold the car and it now resides in Switzerland.
Thank you
