07-09-2017, 06:17 PM | #1 |
Crank starter
I'm trying to get my A back on the road after 20 years in the garage. I wanted to turn the engine over by hand a little and let some oil work its way through the engine.
When I put the crank in the front of the car and pulled it wouldn't budge. I'm not the strongest guy but not I'm not exactly weak, am I missing something that would prevent the engine from turn with the crank? Some safety catch I'm missing? Or am I looking at a seized engine? Thanks for all the help guys! |
07-09-2017, 06:33 PM | #2 |
Re: Crank starter
Is the transmission in neutral? Could be a stuck engine or jammed starter drive.
Bob |
07-09-2017, 06:39 PM | #3 |
Re: Crank starter
First thing I would do is pull the plugs and put about an ounce of MMO in each cylinder, let sit 1 day, repeat, let sit, repeat, etc for a week. Then try the crank again, OR, place in gear and gently rock the car back and forth, but don't try pulling the car around to break it loose. Gently work the engine, it will come loose with a gentle touch and patience. The harder you try, the higher the chance of seriously breaking something.
Before Walmart you had to buy a ticket to the fair to see a bearded lady! |
07-09-2017, 06:41 PM | #4 |
Re: Crank starter
Any chance there are one or more cylinders full of water? Did you remove the plugs (and hopefully squirted a little oil in) before you tried to turn it?
Charlie Stephens |
07-09-2017, 06:42 PM | #5 |
Re: Crank starter
I have had that on cars I purchased....took the plugs out and put in Marvo Mystery Oil...could use Kroil ...I think it is the best on the market...
It may take several days to break it free....just put the car in 3rd gear and rock it back and fourth over and over...at first it will seem like nothing changed...but the second day it may move a tad...by the third day it should turn all the way over...etc... Then use a good battery and crank it for about a minute...leave it for an hour...crank etc.etc.... after a few days of doing this...put the plugs in and fire it up...may still have stick rings but they should come loose with all that Marvo oil you put in er... Joel |
07-09-2017, 06:48 PM | #6 |
Re: Crank starter
Worst thing with a head gasket is if it had anti-freeze in it...the bearings are probably gone... Anti-freeze turns babbit into soap...not the kind you was your hands in ...it eats holes in the babbit...they holes will be black...really ruins bearings.....ie.. Black Holes Joel |
07-09-2017, 06:57 PM | #7 |
Re: Crank starter
I did put some MMO down in the cylinders, the spark plugs look a rough and I intended to change them. The Radiator is still full so I don't have anyway to know if the head gasket is blown or not. I'll let it soak and try gentle rocking the car after its had time to work into tie cylinders.
07-09-2017, 09:04 PM | #8 |
Re: Crank starter
Loosen the oil drain plug until only a couple of threads are holding, and see if any coolant drips out(water/coolant settles to the bottom). Then change the oil. Remove the starter in case it is jammed.
Pull the distributor and pour a quart or two of oil in the opening after draining oil (to get oil to the dipper tray and mains right away). Consider that condensation over the years may have rusted holes in the bottom of the dipper tray, thus draining away oil that should stay in the tray. |
07-10-2017, 07:35 AM | #9 | |
Re: Crank starter
07-10-2017, 07:45 AM | #10 | |
Re: Crank starter
this is the best Ive ever used,it cuts corrosion like no other. |
07-10-2017, 07:58 AM | #11 |
Re: Crank starter
Put the car in third gear and push it both ways to see if the engine will move. Might be a little easier than pulling on that crank.
07-10-2017, 08:19 AM | #12 |
Re: Crank starter
07-10-2017, 09:20 AM | #13 | |
Re: Crank starter
07-18-2017, 07:44 AM | #14 |
Re: Crank starter
Thanks for all the great suggestions guys! after letting the engine soak in MMO for a little over a week and some gentle rocking, the engine is no longer seized. I'm going to keep working the crank with some MMO and fresh oil to help relubricate engine parts but this (what I consider) a major hurdle that i've gotten past on my on way to starting my model
a! |
