01-29-2023, 01:42 PM | #1 |
Brake Parts / Ford Dimensions
Has anyone got the correct specs for the brake roller pins and the rollers? A curious mind wants to put them in his notes for his grandsons. Hopefully, someone has the Ford drawing or a reliable source???
Roller pin length Roller pin shank diameter Roller pin head diameter Roller pin head thickness Roller diameter Roller hole diameter Thanks
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!" |
01-30-2023, 09:39 AM | #2 | ||
Re: Brake Parts / Ford Dimensions
This sounds like a job for the ORIGINAL DRAWINGS.
https://www.thehenryford.org/collect...parts-drawings And a similar request over at the T Board Quote:
IIRC, there is a charge for "duplications" which is not large, but there is inherent some question about "are you paying for what you want." And should you choose to "replicate" for profit there is the copyright matter and attribution agreements. The Index may help. Some here who are into reproducing likely can tell you more of the pitfalls. And may share (generously) what drawings they have "offline" (ahem.) But your parts of interest are so severely "common" that even that is unlikely? I commend your interest for "originality." So much of what is in the marketplace comes with decidedly "uncertain" pedigree. The recent discussion of "clustershaft roller bearings" comes to mind. It is better than it used to be. Joe K
Shudda kept the horse. Last edited by Joe K; 01-30-2023 at 09:51 AM. |
01-30-2023, 10:23 AM | #3 |
I have the prints but I am not where I can view them at the moment. By memory, I can tell you the pin is 7/16" in diameter (0.4375") and the hole in the Roller is 0.4380" and the OD is 1.250". I will get you the print numbers if you like later today or this evening.
01-30-2023, 11:10 AM | #4 | |
Thank you, Brent. I'll appreciate getting them.
Thread Tools | |
Display Modes | |
