Old 07-31-2021, 10:20 PM   #1
tubman
tubman's Avatar
Default For forum member "Pdstark"
Phillip,
For some reason, I couldn't send a picture in a PM, so I'll post it here. I got this picture from another person I sold a condenser to who mounted it on a '52 Mercury. He says it look good and works good. You will notice that the yellow wire from the condenser goes to the appropriate terminal on the coil rather than the distributor. This works fine, as they are electrically the same. I believe that he used an additional small bracket to make this work.
Old 07-31-2021, 11:39 PM   #2
Pdstark
Pdstark's Avatar
Default Re: For forum member "Pdstark"
Thanks Denny! I appreciate this example. Looks like it will work fine. It was great to meet you and spend time talking cars.
“Wherever you go - there you are”
Pdstark is offline   Reply With Quote
