07-17-2021, 11:15 AM | #1 |
Steering column support
I purchased the parts necessary to change the column mount on my 29ccpu.the info from tom endy shows the 3/8 steel plate mounted on the gas tank flange but i will have to remove a existing bolt to mount the plate to the flange,from what i can ascertain the 3/8 plate is under the tank flange,correct? Also the dash rail has a curve and the tank flange follows suit possibly i can duplicate the curve in the press.i'm going to countersink the support studs in the plate and weld them in pointing down naturally.the steering support mounting surface is flat i might have to put a spacer in between the mtg. Bolts as not to snap the ears,any comments and suggestions are welcome,thanks.
07-29-2021, 11:23 AM | #2 | |
Re: Steering column support
07-29-2021, 01:26 PM | #3 |
Ruth "Sometimes you really DO need to read the whole thread" |
Thread Tools | |
Display Modes | |
