12-03-2020, 12:02 PM | #21 | |
Re: A forgotten in plain site 1936 Model 51
1936 Model 51 "Well, ain't this place a geographical oddity. Two weeks from everywhere!" Everett Ulysses McGill |
12-03-2020, 12:31 PM | #22 |
Thank's Mercman.
12-03-2020, 12:34 PM | #23 | |
12-03-2020, 12:39 PM | #24 | |
Jeff
1936 Model 51 "Well, ain't this place a geographical oddity. Two weeks from everywhere!" Everett Ulysses McGill Last edited by Scavenger One; 12-06-2020 at 05:34 PM. |
12-03-2020, 01:21 PM | #25 |
i think the steel mud flaps are a ww2 army item. perhaps even the whole bed is off an army truck. usually have a data plate on the front
12-03-2020, 01:36 PM | #26 | |
If there was a Data plate, where would it have typically been located on the front?
12-03-2020, 02:06 PM | #27 |
Welcome, great looking truck, looking forward to seeing your progress on this journey. Keep the pictures coming.
12-06-2020, 08:23 AM | #28 |
best of luck with the truck. I am also new to the site. I have a bunch of parts and I am learning which are pickup and which are 51.
12-06-2020, 02:48 PM | #29 |
I too have been enjoying your tale. Good reading and nice truck for sure! As said, more pictures please.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
12-06-2020, 03:48 PM | #30 |
I have glass for your doors free if you want it.
12-06-2020, 05:24 PM | #31 |
Thanks Muggsy. I sent you a private message
12-06-2020, 07:15 PM | #32 |
I need to post so I can reach 10 to be able to respond to pm
12-06-2020, 10:49 PM | #33 |
It would be cool if you could carefully remove some of the green paint only to expose any lettering to prove it was a demonstrator truck.
12-07-2020, 12:11 AM | #34 |
Attached is a picture of an owners manual I found useful while restoring my 36 1.5 ton. It is available from several online sources.
12-07-2020, 10:00 PM | #35 |
That is something I have been thinking about, how to do it without damaging the letters underneath. If you know what you are looking for you can just barely make out the V of the "V8" on the doors, but if I could just remove just enough of the outer layer of paint to reveal it better or find the "Demonstrator" letters above the windshield. But even with out that I am confident in what it originally was based on the original paint colors and the faint lettering on both stake body panels.
12-07-2020, 10:01 PM | #36 |
Yes, that is definitely on my short list of wants.
12-08-2020, 12:51 AM | #37 |
i once bought an army dump truck that had been painted white for "winter training" . i sprayed simple green on it for a few days and hit it with a hot water pressure washer and had an army green truck again with all its markings
12-08-2020, 11:33 AM | #38 |
If you have power take off, then you have a hydraulic dump. I have model 79 ('37) with hydraulic dump made by Garwood. Look for "brass plates" on passenger side of frame (just past cab) for "operation/maintenance" of the lift. Also, many times there was a "plate" on floor board in cab with "how to operate" the lift. My dump truck has 35,000 original miles so I was lucky to have these plates still in place. I can send you copies I can send you if you like .
Henry |
12-11-2020, 11:54 AM | #39 |
cas3, Thanks for the idea. I am thinking I may try that first.
12-11-2020, 12:04 PM | #40 | |
I am still on the fence as to if I am going to keep it on the truck or remove it. If you can send me the info, I would still appreciate it for if only the knowledge but may still come in handy if I do decide to keep it on the truck.
Thread Tools | |
Display Modes | |
