10-16-2020, 10:13 AM | #1 |
wiper arm and pivot 55 crown vic
my wiper pivot measures 0.537 and my wiper arm 0.549 way to big
mine looks like MACS 17526-062 generic also MACS says there is 4 different arms for 55-56 MACS also shows 6 7/16 and 6 1/4 for convertible and crown vic HELP ! |
10-16-2020, 04:19 PM | #2 |
Re: wiper arm and pivot 55 crown vic
Now you know why they have the adjustable aftermarket arms on there. Those only cost $39.99 while the correct repro CV, convertible arms cost $97.99.
If you get the 6-1/4" long repro's with bayonet arm (# B5A17526-DPR) and pay the big bucks, they'll fit on your pivot fittings but then you may need to pay more to get wiper blade assemblies to fit the bayonet type arms. I don't like those adjustable aftermarket types, because if your vacuum wiper motor is not fully returned to zero, the pivots are not all the way down and you will suck a small amount of vacuum all the time. To install the correct wiper arms, remove old wiper arms first, then start engine, run the wipers thru one cycle and shut off with engine running and no wiper arms, so that the pivots will return to zero vacuum position. Then install wiper blades on wiper arms and press wiper arms onto the pivots. If you get an arm one notch off, you can remove and re-install again till you get both to match. |
10-16-2020, 07:43 PM | #3 |
The reason being is there were two roof heights in 55/56 depending on body style. My cataloging is hidden so I can't give you details right now.
- AT MY AGE, ONE APPRECIATES A STURDY HANDRAIL - |
10-17-2020, 08:29 AM | #4 |
my problem is my pivot is smaller than the hole in the arm
pivot 0.537 arm hole 0.549 when i turn electric wipers on wiper don't move pivot is spinning in arm |
10-17-2020, 01:42 PM | #5 | |
Or you have the wrong arm assy. Any Casting I.D. on the arm assy?
10-17-2020, 10:55 PM | #6 | |
ALSO, there are different style arms to fit mating blades. You can get them in either bayonet style or wrist-type arms. When the wiper system was converted to electric, did they supply the actuator arms (under the dash)? If so, those may have had smaller pivot male ends and you will have to match that size. Last edited by Daves55Sedan; 10-17-2020 at 11:01 PM. |
