Old 08-23-2020, 12:17 PM   #1
D. Jones
D. Jones's Avatar
Default Drag link 1945 1/2 ton pickup
I need to replace/repair the drag link on my 45 1/2 ton, the fixed ball end is loose. I've done a search here and looked at many posts and it appears there is no good solution. Some seem to suggest that a kit from Speedway was the answer but, all the kits I saw were for a straight tie rod or drag link, mine has a step or bend so, it appears to me, a straight one would have the ball setting at an acute angle. Am I missing something or am I just not seeing the correct solution?
D. Jones is offline   Reply With Quote
Old 08-23-2020, 02:47 PM   #2
Fordestes
Default Re: Drag link 1945 1/2 ton pickup
I bought one for my 46 half ton ,21A3306 ,I think it was from midwest ford, mine is a cross steer, the 40 looks almost the same but is a little shorter and will allow the gear to not be centered and cause slack in the steering from not being in the correct spot of the worm gear.
Fordestes is offline   Reply With Quote
Old 08-23-2020, 03:13 PM   #3
Fordestes
I just looked up the number 21A 3306 and it shows to be a passenger car, the comm. part number is 21C3306, mabe someone will clarify this for us, the length of my link is 30 1/2 inches center of ball to the end of the rod and 31 inches overall outside without the sleeve and tie rod end installed.
Old 08-23-2020, 04:10 PM   #4
35fordtn
35fordtn's Avatar
We have the 21C NOS in stock I think only one. If I remember I’ll measure this week
35fordtn is offline   Reply With Quote
Old 08-23-2020, 06:51 PM   #5
Bob NH
Bob NH's Avatar
Joe's antique lists a drag link for both cars and trucks ,21A-3306 42-48 $85.00
Bob NH is offline   Reply With Quote
Old 08-23-2020, 07:11 PM   #6
leon bee
My 46 has a home-made one, two chunks of rod welded together with a tie rod end on both ends. This problem must be why.
leon bee is offline   Reply With Quote
Thread Tools
Display Modes
