Old 08-19-2020, 02:09 PM   #1
cederholm
cederholm's Avatar
Default GAV leaking
With the air filter removed, and the car not running, the throat of the carb intake is pooling with fuel. I believe my GAV is fully closed so I assume the needle isn't seating fully.
Thoughts/advice?
Thank you,
Carl
cederholm is offline   Reply With Quote
Old 08-19-2020, 02:21 PM   #2
Ernie Vitucci
Default Re: GAV leaking
Good afternoon...You might with to check your float level...Ernie in Arizona
Ernie Vitucci is offline   Reply With Quote
Old 08-19-2020, 02:24 PM   #3
cederholm
cederholm's Avatar
Ah, inserting. What is the rule of thumb for setting that?
Old 08-19-2020, 03:00 PM   #4
ryanheacox
ryanheacox's Avatar
You want the gas level ~5/8" below the gasket, some like 15/16". A good rule of thumb is to have the seam of the float at an even 1" from the casting with the upper half flipped upside down. This info is all for the Zenith. You also want the cap jet to have a depth of 7/16" from the machined surface of the lower half and the main jet to have a depth of 3/8".
ryanheacox is offline   Reply With Quote
Old 08-19-2020, 03:08 PM   #5
cederholm
cederholm's Avatar
Awesome, thank you.
Old 08-20-2020, 05:48 AM   #6
Ed in Maine
You should also remove the float valve and wipe it off with Carb Cleaner, Lacquer Thinner or Acetone. Float valves are a problem area with the Model A. It is a good idea to install the small tubular filter into the inlet of the shutoff valve available from Synders and others. I also like a lower float level than 5/8 in. As long as the compensator jet remains flooded at all times, the 5/8 in. float level is not critical. With the float level at 5/8 in., the gas level in the cap and main jets is right at the top of the jets and if you park on a hill going up hill, the carb could leak into the street! I prefer 11/16 in. to 3/4 in. Good luck with your repair, Ed
Ed in Maine is offline   Reply With Quote
Old 08-20-2020, 08:20 AM   #7
johnbuckley
johnbuckley's Avatar
"With the air filter removed, and the car not running, the throat of the carb intake is pooling with fuel. I believe my GAV is fully closed so I assume the needle isn't seating fully."
The GAV needle won't cause fuel to leak out of the carb, a non sealing GAV needle will cause rich running but will not cause fuel to pool in the throat of the carb.
Your problem is number 1,2,3,4,5,6,7,8,9,10 on the list below you'll probably find it's 1 or 2 if it's been OK up til now
Problem: Remedy
1 Leaking/loose float valve gasket: Tighten/reseal/replace
2 Leaking float valve: (or crud stopping it sealing)Replace ( or clean up if possible )
3 Friction on float hinge: Loosen
4 Incorrectly set fuel level: Re-set
5 Hole in float: Repair or replace
6 Too many gaskets on main jet Check
7 Cap jet or main jet too short: Replace
8 Leaking/loose gasket at main jet: Tighten/reseal/ replace
9 Leaking /loose gasket at cap jet: Tighten/replace
10 Leaking or loose GAV housing threads: Tighten/ reseal/ replace
11 Leak at fuel inlet union: Tighten/reseal/replace
12 Loose/leaking gasket at strainer: Tighten/reseal/replace
13 Loose/leaking gasket at drain plug: Tighten/reseal/replace
14 Cracked housing/leaking passage plugs: Repair or replace
johnbuckley is offline   Reply With Quote
Old 08-20-2020, 09:53 AM   #8
redmodelt
redmodelt's Avatar
The GAV is not a shut off. If you try and use it as such you can/will score the tip when trying to close too tight. The GAV does not need to be shut down every time the car is stopped. Once you find it's best position, leave it and only open enough to start the car then return it to the best run position.
Old 08-20-2020, 02:13 PM   #9
cederholm
cederholm's Avatar
Fantastic info all - I will follow your instructions.
Thanks,
Carl
Thread Tools
Display Modes
