Old 08-06-2020, 12:25 PM   #1
dmaxweb
dmaxweb's Avatar
Default Copper Manifold Gasket Orientation.
I'm installing 2 piece copper manifold gaskets. I've done this a number of times but it never occurred to me if it matters which side goes against the block. One side is formed slightly different than the other. Does it matter?
dmaxweb is offline   Reply With Quote
Old 08-06-2020, 02:08 PM   #2
Russ/40
Russ/40's Avatar
Default Re: Copper Manifold Gasket Orientation.
The conventional wisdom is the same as head gaskets. The uninterupted surface goes against the block.
Russ/40 is offline   Reply With Quote
