Old 07-27-2020, 05:33 PM   #1
Kiwi73
Default 42 Truck Hood Bracket
Hi, Trying to mount my hood (bonnet) on our 3 ton 42 Jailbar truck. Someone has attached the hood bracket (not hinges) with bolts that seem way to small for the hole in the cab(hole is about 10mm diameter - bolts are 4mm). Consequently the bracket doesn't feel secure. Is there some insert for the holes in the cab? Can someone provide details (or photos) of what size/type of bolts/fittings should be used here? I've seen heaps of details about hinges on these threads but not the bracket. Cheers!
Kiwi73 is offline   Reply With Quote
