06-08-2013, 09:04 PM | #1 |
oil pump shield
Where can I get an oil pump shield for my full pressure B engine
06-08-2013, 09:18 PM | #2 |
Re: oil pump shield
Snyders has it in their catalog listed as for a 31, but I think they fit a B engine as well. The pumps are the same size, even though the inside shaft differs
06-08-2013, 09:21 PM | #3 |
Re: oil pump shield
Snyders Part # A-6631
07-26-2020, 09:03 PM | #4 |
Re: oil pump shield
So has the shield been used successfully with the pre late 1931 oil pans by trimming the shield bottom ? It appears the oil pump holds it up to the block. If the gasket is used, where is it placed? Are any other mod's to the oil pump required ?
07-27-2020, 03:41 AM | #5 |
Re: oil pump shield
No mods to the oil pump . No gasket required .Years ago in my innocents I fitted the shield from a "B" engine into a "A" engine with no apparent ill effects .I recently pulled the pan off this engine and removed the shield . No damage/buckling was found . Could be the shield was for an "A" engine anyway . Someone on the site must know the different skirt length between "A" and "B" hope they chime in .
John in light cool rainy morning in Suffolk County England . |
07-27-2020, 04:43 AM | #6 |
Re: oil pump shield
John in same place same weather . |
07-27-2020, 04:50 AM | #7 |
Re: oil pump shield
Model A Medic sells one that works with the standard Model A Dipper Tray. Easy fit. I have used several.
07-27-2020, 07:36 AM | #8 | |
Re: oil pump shield
Yes John, page 576 The detent on the dipper tray was raised 1/8 inch, which lowers the tray itself. Kinda sounds like they were worried about the shield hitting the tray maybe Huh? I wonder if they found the shield hitting the tray and vibrating? The bulletin also says NEVER INSTALL shield without the new tray. Last edited by Benson; 07-27-2020 at 12:31 PM. Reason: Blue is additional text |
07-27-2020, 08:06 AM | #9 |
Re: oil pump shield
PM me as I have an original one for sale from a B engine.
07-27-2020, 08:48 AM | #10 |
Re: oil pump shield
Surely Glen has found a shield in the last 7 years but I am not sure that a shield is needed on a B engine with pressurized rod bearings as the dipper tray has no dippers needing to pick up oil for rods.
07-27-2020, 09:58 AM | #11 |
Re: oil pump shield
So what is that shield actually supposed to do?
07-27-2020, 10:36 AM | #12 |
Re: oil pump shield
Where does the A6626 gasket go ? Against the oil pump or above shield to block, if that makes sense? Also, if ones installs the accessory valve cover oil filter, are there any adverse effects with the shield?
07-27-2020, 12:14 PM | #13 |
Re: oil pump shield
Attached article about oil pump shield.
Tom Endy |
07-27-2020, 12:43 PM | #14 |
Re: oil pump shield
That is the Oil Pump Screen Cover Gasket. It goes between the metal Screen Cover and the A-6604 Oil Pump Body.
07-27-2020, 03:48 PM | #15 | |
Re: oil pump shield
cover". No other gasket needed except the gear cover gasket on the bottom of the pump and nothing extra for the shield. So the pump body is the only thing holding the shield up into the block, and trimming it to fit an older tray shouldn't be a problem unless the repro shields have folded metal bottoms. I haven't been able to understand from other threads whether there is an adverse reason if the tray should be lower in the pan other than for shield fitment and/ or it affects the splash system lowered an additional 1/8". Evidently the engineers didn't think so? Last edited by duke36; 07-27-2020 at 03:55 PM. |
07-28-2020, 11:54 AM | #16 |
Re: oil pump shield
On a full-pressure system the most important thing is to baffle the oil so it doesn't run away from the pump on acceleration, deceleration or hard right turns. On some of my engines I don't even run the dipper tray, just baffles that I have installed in the pan itself.
07-28-2020, 12:05 PM | #17 |
Re: oil pump shield
glen passed last year..he doesn't need a shield..hopefully
