07-23-2020, 06:15 PM | #1 |
Best way to fix this header
This is the Reds header off my '41, can this be tig,mig,or stick welded? What's best.
07-23-2020, 06:35 PM | #2 |
Re: Best way to fix this header
tig would be best, mig will work. i would bolt it to a hunk of steel as it will move around on ya. use an old iron manifold for a pattern. actually, an early manifold would work perfect, flat on both sides
07-23-2020, 06:46 PM | #3 |
I don't think I'd grind away the old weld as it provides a solid foundation.
07-23-2020, 06:53 PM | #4 |
I also had to cut the pipe from the manifold to the muffler, I hope this can be put back together
07-23-2020, 06:54 PM | #5 |
depends on how thin the metal is and how much carbon from the exh. is imbeded in the header as to how hard it will be to repair it, but it is do able.
07-23-2020, 06:55 PM | #6 |
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
07-23-2020, 07:25 PM | #7 |
If you don't have a block to bolt it to, bolt it to an opposite-side exhaust manifold. Better than nothin'! DD
07-24-2020, 12:38 AM | #8 |
It's just steel not cast iron. Weld it like anything steel. gap is large so address that. I'm guessing you can weld something.
07-24-2020, 01:56 AM | #9 |
I think Ronnie's idea will be best, especially if you mig weld it. If you choose that, make the patch out of .094, that way, you can hold most of the heat on the patch and let it flow on to the tubing, w/o any worry about burning threw the header tube.
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline |
07-24-2020, 03:33 AM | #10 |
Post#4.....NAPA sells different couplings in assorted ID/OD and lengths. You should be able to find one to repair the end of that pipe......Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
07-24-2020, 04:51 AM | #11 |
Getting that part adequately cleaned for TIG welding could be a major project. Even a MIG weld could exhibit some porosity tendencies. I would either stick weld or use the torch depending on the status of the material. And, yes, should be clamped to block or stiff object with hole centers aligned and maintained.
07-24-2020, 06:36 AM | #12 |
Thanks for the advice, I do have a couple of bare blocks in the shed I could use.
I bought this HF welder about 8 months ago for a different project and have only used it for a few practice welds, I don't have 220 at my house so this was my only option, I also have a roll of Hobart .030 wire on it, if I don't think I can do it I'll have to take it somewhere. |
07-24-2020, 08:14 AM | #13 |
Do you have torches to gas weld it like mentioned above?..... Mark
07-24-2020, 08:21 AM | #14 |
07-24-2020, 08:37 AM | #15 |
Once bolted to a block it might be difficult to get in the right position to weld with a TIG or MIG. I like the idea of bolting it to an exhaust manifold for more room. A lot will depend on how good a welder you are. That is relatively thin and it looks like an old weld is there so you will be welding something thinner to something thicker. Do you have a lot of experience? I generally use my TIG on clean and well fit up new metal.
IF it was mine I would blast the inside and outside to remove rust and old carbon first, otherwise you will have contamination, then lightly grind with roll lock disk the old weld. Welding is all about the puddle, and getting in a comfortable position. Good luck. |
07-24-2020, 09:21 AM | #16 |
Ronnie Roadster has a repair that can be done with a patch.If it was mine that is what I would do.This is a repair that silicone bronze would help with a tig. The patch has to be a good fit.
R |
07-24-2020, 10:09 AM | #17 |
I'll be the odd man out here. That looks like a rust through (or burn through) and there are probably other similar areas in the header. It looks to me like its time for a new set of headers. Nothing to lose by trying to fix it, though. I would try.
07-24-2020, 01:03 PM | #18 |
Personally, if the header's pipe is thin enough that it tore at the weld, I'd just replace it with a new header.
The pipe would be easy to weld back up with a MIG welder. It would be much more forgiving and easier than doing it with TIG.
Mike Wanted: - '32-34 Open Cab Pickup (RPU) parts and documents/articles/info - ARDUN parts |
07-25-2020, 02:23 PM | #19 |
Find a shop that has the equipment and skill to do the job. At our shop we weld most things that haven't had amateur work already done that affect the alignment of the pieces.
07-25-2020, 02:59 PM | #20 |
Looks like it got hit up and the weld broke at the weakest part. See the bend on the bottom of the weld. Make a patch and cover the area after it is bolted to a block. The metal in that area is stressed and weakened. Do a farmer fix. JMHO
