Old 07-17-2020, 09:48 AM   #1
dgkipp
Default Problem with high oil pressure?
Hi guys, seen a lot of talk with engines with low oil pressure problems, but I have a recent rebuild with high oil pressure.
The engine does have a high volume pump on it with remote oil filter.
cruisin pressure is about 80#, 40 at hot idle. Now has a couple thousand miles on it with no problems. Should I be concerned ?
dgkipp is offline   Reply With Quote
Old 07-17-2020, 09:56 AM   #2
51woodie
51woodie's Avatar
Default Re: Problem with high oil pressure?
What grade of oil are you using? Also helps to know what engine you are running. If you are using something like 15-40, try a lighter oil.
51woodie is offline   Reply With Quote
Old 07-17-2020, 10:25 AM   #3
grumppyoldman
grumppyoldman's Avatar
My 41 V8 did the same after re-build now it will go up to 80psi. on start-up then drop back to 40 when running and 20psi at idle when hot. I use 30wt. Valvoline Racing oil because it has zinc in it which is needed for these flathead engines with flat tappet lifters. With it running at idle all you can hear is the fan belt squeeking. Al
grumppyoldman is offline   Reply With Quote
Old 07-17-2020, 10:26 AM   #4
richard crow
make sure of those readings with a mechanel gauge
richard crow is offline   Reply With Quote
Old 07-17-2020, 02:09 PM   #5
Ronnieroadster
Ronnieroadster's Avatar
Theres no reason to be concerned at all from my many decades of experience
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
Old 07-17-2020, 02:21 PM   #6
JimNNN
No experience with flatheads but an experienced engine builder told me that my FE's high oil pressure at startup was from a high volume oil pump. Likely that's what's going on with you, given your pump choice. Were the engine not recently rebuilt a blocked passage could be possible. I'm guessing that's not the case. I personally wouldn't worry about it since you've had no issues.
JimNNN is offline   Reply With Quote
Old 07-17-2020, 02:28 PM   #7
Step-down
Step-down's Avatar
GOM
That Valvoline Racing oil my have Zinc but do you know if it’s non detergent or not .
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 07-19-2020, 11:08 AM   #8
grumppyoldman
Yes it's detergent oil. has been recommended for flathead Ford's. Al
Old 07-19-2020, 01:38 PM   #9
5851a
Hi volume and high pressure are 2 separate things. I'm not old enough to know if both were available as one pump. But I've primed enough OHV Fords to know that you can burn up 110 volt Dewalt trying to prime a engine with high pressure pump at 70 degrees and 10W30 oil. I just stick with stock pressure pumps and volume nowadays.
5851a is offline   Reply With Quote
Old 07-19-2020, 01:55 PM   #10
51woodie
51woodie's Avatar
Volume and pressure are related. Higher volume through a fixed orifice will result in higher pressure. Pressure is only the resut of resistance to oil flow. The fixed displacement oil pumps in our engines only provide flow, given its displacement per each turn of the pump. What will vary the pressure is the viscosity rating of the oil, the oil temperature, relief valve pressure settings, a leaking relief valve and/or worn engine components.
Old 07-19-2020, 02:14 PM   #11
Joe Immler
Grumpy- My '41 Coupe engine has the same oil pressure as yours. I use Valvoline also.
I installed mechanical oil pressure and water temperature gauges at the bottom of the dash so I know the readings are good. And I'll be damned- I can hear my belt too.
Whooda thunk it?
Joe Immler is offline   Reply With Quote
Thread Tools
Display Modes
