Old 07-09-2020, 02:43 PM   #1
zoegrant
zoegrant's Avatar
Default Electric fuel pump test ?
Is it possible to test the pressure put out by my electric fuel pump ?
I would like to know how much fuel pressure I have at the carb.
I am not running a mechanical pump, just the electric one.
zoegrant is offline   Reply With Quote
Old 07-09-2020, 03:18 PM   #2
Phil Gillespie
Phil Gillespie's Avatar
Default Re: Electric fuel pump test ?
Yep just Tee in on pump discharge line to carb and fit a pressure gauge here.
Type of carb in use will dictate required pump discharge pressure.
Too much may cause leak by and too high float level.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 07-09-2020, 03:23 PM   #3
vincent
I fitted a pressure regulator to my electric 4 psi pump, have no mechanical pump either. Tested it right now and it seemed to help my carburation - no stinking/black smoke anymore and gained another 10 km/h.
cheers, Harty
vincent is offline   Reply With Quote
Old 07-09-2020, 03:47 PM   #4
adileo
adileo's Avatar
This help
File Type: jpeg 515F6F36-6699-4BB9-8714-1D9D5A3C9047.jpeg (114.4 KB, 56 views)
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 07-09-2020, 04:49 PM   #5
Ronnieroadster
Ronnieroadster's Avatar
You sure can its easy to do using any type of low pressure gauge. To test the pressure output from the pump no need to add a Tee fitting. All you need to do is connect the fuel line thats on the carb directly to the pressure gauge. Once you turn the pump on you will see the pressure output on the gauge from the pump. Some electric pumps will shut down once the flow stops so the pressure reading will go down once that happens. Prior to that you will see the pressure reading on the gauge.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
Old 07-09-2020, 05:37 PM   #6
grumppyoldman
grumppyoldman's Avatar
I have a Mr Gasket pressure regulator in line ahead off gauge { cheap regulator } and when the regulator shows 1#, the gauge shows 2 1/2 # which is all the engine requires. I'm also running only electric pump mounted near gas tank on 6 volt system. Without the regulator I had 6# fuel pressure and the engine tried to flood at low speeds. Al
grumppyoldman is offline   Reply With Quote
