07-07-2020, 08:36 AM | #1 |
Starting The Flathead
In a couple weeks I will start the flathead for the first time since I heard it run on an engine stand. It ran with original intake and single carb. It now has two Stromburg 97`s rebuilt by uncle max. I will set the points and check on the timing. everything seems to be tight and ready to go. I`ve done single and 4bbl carb adjustments but not sure which carb i should start with or maybe it doesn`t matter. Any other suggestions on this start up I should be thinking about? Thank you.
07-07-2020, 10:30 AM | #2 |
Re: Starting The Flathead
On both of my cars with 2 97s, I leave one carb unchoked and half choke the other. When the temp gauge gets to 150 I unchoke it and mine will idle at that point off fast idle setting and then I can drive it and it will go up to temp. My engines don't run that well until they get to 150 degrees. I know all engines/cam and carb combinations are different.
07-07-2020, 10:38 PM | #3 |
Run it hard , drive it with plenty of load and varying speeds. Dont stand back taking videos of it of it idling ! run it in..
07-08-2020, 04:10 PM | #4 |
Sorry for the late reply, been very busy. Thank you for the tips
07-08-2020, 08:58 PM | #5 |
did you sync the two carb?
07-08-2020, 09:30 PM | #6 |
07-08-2020, 10:13 PM | #7 |
then why use an AF meter if synching is a waste of time?
07-09-2020, 02:45 AM | #8 |
My thoughts on syncing carbs is.
If you have a fourcylinder or eight cylinder with weber carbs, syncing is a must, since its like one carb for each cylinder. Think of a MC with four carbs. If you have a flathead with two carbs one side of the two Stromberg carb gives airfuelmix to four cylinder's. and if one is a bit off its no big deal. AF meter is more important , since it gives you an idea what airfuelmix the cylinder get from the two carbs, and you don want it to be lean or fat, |
07-09-2020, 10:33 AM | #9 | |
07-10-2020, 07:59 AM | #10 |
Back a few hundred years ago, when I first sterted into flatheads I had a 2 duce intake with the gen in the stock place. My friebd said I had to Synk the carbs and he had this littel gaget you put on the carbs . We spent several days trying to SINK them. Couldn't Today I know why, I think, However, this synk is only an idle condition and has very little to do with driving around town or atrip to grandma's.
Gramps |
07-10-2020, 01:30 PM | #11 |
If you idle off of one carb it's impossible to synchronize them with an air flow meter ( a snail)to synchronize them both have to equally share the idle load.
07-11-2020, 07:23 AM | #12 |
Jack, Yes, I know that. Just think it's simpler this way.
07-11-2020, 07:35 AM | #13 |
What intake manifold are you running? If it has the carburetors set back for generator clearance you'll never be able to sync them with the air flow meter, the rear carburetor will have to be so far open to compensate for being so far back that the idle will be racing.
If you have a manifold where they are spaced evenly apart and you are using direct non progressive linkage then they should both have idle speed screws and they should be tuned so it idles nice and pulls the same amount of air through each carburetor. |
07-11-2020, 01:48 PM | #14 |
This thread makes a good point. Not everybody has one of these sync devices but would like to go for a ride. The method I've used for years, is to use a block off -late over one carb on the itake, or two if it's an triple intake Adjust one carb at a time for proper vacuum and then put them together. I still crack the front carb, I never use the street intakes they neer work right and are just for show. I use the compition intakes especially the Offy hi rise, it;'s about an inch higher than the Edelbrock unit. In the old days we had to use an offset gen bracket, but now tey make a short 12v unit the sits in front of the carbs. I;m using this on the roadster engine, with the Holly 94 style 1 1/16 venturis on the street. I have a special track intake,
