Old 06-30-2020, 08:23 PM   #1
mrtexas
mrtexas's Avatar
Default Electric fans
I know this is not flathead related but lots of hot rod experience here as well. I have a 41 flathead in addition to a hot rod 49. Have a 49 hot rod woody with Ford 302 v8. It came with a 16 inch pusher fan. No room for a crank pulley fan, engine needs to be a couple inches back for that and I don't feel like moving the engine back, modify the firewall, modify steering, cut the driveshaft, new motor mounts, new transmission mounts. When I added AC it started to heat up, maybe overheat. Guy from Walker radiator said Vintage Air condenser blocks air flow too much so bought a Walker condenser that is bigger.
So cruising the web pusher electric fan not near as good as puller? I started the car up yesterday and got the pusher fan running. Sure enough there was a LOT of air hitting my chest even though the fan was pushing thru the radiator. Even removed the DC motor fan to make sure it was turning the right way.
Well the crank pulley is less than an inch from the radiator so not much room for a 16 inch Spal puller fan that is 2 inches thick in the low profile version. So I measured the space for multiple smaller fans. I can fit 3 9 inch fans. Turns out 3 9 inch fans move as much air as a single 16 inch fan. Also amps of 3 9 inch fans 22 anps pretty close to 16 inch fan amps of 21. Will verify the smaller fans fit tomorrow.
So I went to my favorite sheet metal shop and had a fan shroud made up today. I'll put two of the puller fans across the bottom and one fan on the top driver side as in the picture. Have enough room to dodge the serpentine fan belt which is 2 inches from the radiator. Not enough room for 4 nine inch fans either, could put a 7 1/2 inch 4th fan but then 5 more amps.
Some web sites said you need 2500cfm for a v8 but 16 inch fans which seem to be the biggest available only put out 2000cfm. 13# radiator cap. What would max water temp be for that?
What about the passenger side of the fan shroud? Leave it blocked off or put a hole in it to let air flow thru the radiator?
Palindromes:
Do geese see God?
Was it a car or a cat I saw?
Won't Neil call a Walla Walla client now?
Dr. Gong! Get ale to my motel at Egg-nog Rd!
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 06-30-2020, 08:46 PM   #2
40cpe
40cpe's Avatar
Default Re: Electric fans
If you cut a fourth hole, I've seen shrouds with flappers over the vent holes that close when the fans are sucking and open when air passes through at speed.
40cpe is offline   Reply With Quote
Old 06-30-2020, 09:26 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
The three fans will be pulling air thru the fins in unison, suspect that adding a hole will only reduce the efficiency of the three fans by giving a place to pull air from the engine side of the radiator.
Old 06-30-2020, 09:32 PM   #4
JSeery
JSeery's Avatar
Lot of factors, but a rule of thumb is 2-3 degrees for every psi. For a #13 cap, that would be around 26 to 39 degrees. At sea level that would be around 240 to 250 degrees.
JSeery is online now   Reply With Quote
Old 06-30-2020, 09:47 PM   #5
mrtexas
mrtexas's Avatar
good idea
Palindromes:
Do geese see God?
Old 06-30-2020, 10:45 PM   #6
grumppyoldman
grumppyoldman's Avatar
I have a 16" pusher and 2 9" pullers on my 302 and AC, and have no problems with over heating. Being in a 55 instead of A 41 could be some difference in air flow.
grumppyoldman is online now   Reply With Quote
Old 07-01-2020, 09:34 AM   #7
Zeke3
Zeke3's Avatar
It sounds like you have a fairly restrictive cooling package if the 16" pusher fan can't push air through it. I do not think blocking the air flow in the upper quadrant of the fan shroud is a good idea. I think it will kill the air flow in that section of the cooling package.
What are the possibilities of moving the cooling package forward to provide room for an engine mounted fan?
Zeke3 is online now   Reply With Quote
Old 07-01-2020, 09:57 AM   #8
19Fordy
19Fordy's Avatar
Wouldn't it be best to have as much air flowing thru the radiator as possible for water cooling and also to reduce engine compartment heat?
Looks to me like that 3 hole shroud is blocking a lot of air flow, even with the 3 fans.
Why not run 1/8 in. x 1/2 in. flat steel straps horizontally across the radiator and then mount the fans on them without the sheet metal shroud obstruction.You probably could design the straps in such a way that they could hols all 3 or 4 fans.
Don't t the fans each have their own little shroud? That way you get maximum air flow to and thru the radiator for the fans for cooling your engine and reduces high temps. in your engine compartment. Anything that blocks air flow is not good.
Old 07-01-2020, 05:18 PM   #9
4t8v8
I put a 302 in a '84 Bronco II. Had the same problem.Solved it by doing some fabrication and moving the radiator forward a couple of inches. Worked great.
4t8v8 is offline   Reply With Quote
Old 07-01-2020, 05:41 PM   #10
woodiewagon46
Tex, is it possible to move your radiator forward. I know some of the Tri-Five guy's are able move their radiators in front of the radiator support without major modifications. Sorry 4t8, didn't mean to hi-jack your suggestion.
woodiewagon46 is offline   Reply With Quote
Old 07-01-2020, 06:21 PM   #11
V8COOPMAN
V8COOPMAN's Avatar
If you depend on a fan to SUCK air through a radiator, a shroud effectively allows air to be sucked ONLY through the radiator. That's what shrouds are designed to do. Opening a 4th, empty hole in that shroud defeats the effectiveness of the shroud by allowing the fanS to suck air in from the least restrictive area....the big, open hole....RATHER than from through the radiator, which is more restrictive to air flow. This one is not too hard to figure-out. Physics is physics! You can even prove this to yourself by removing the third fan, turn-on the remaining two fans, and feel the suction through the third hole. DD
T5 W/TORQUE TUBE
There are TWO types of people in this world.
___________________________________
1) Those who CAN extrapolate from incomplete data....
Old 07-01-2020, 07:09 PM   #12
tubman
tubman's Avatar
I agree Mr Coopman. There is a guy on the H.A.M.B. ("Hnstray") whose signature is : “In any conflict between Physics and Style, Physics always wins”.
He's right.
Old 07-01-2020, 08:18 PM   #13
40cpe
40cpe's Avatar
Here is an example of flappers to reduce suction loss at low speeds, yet allow air flow through at higher speeds. Sorry for the small size, I lifted it from the 'net.
Old 07-01-2020, 09:09 PM   #14
19Fordy
19Fordy's Avatar
V8; Would it be good to mount a 4th fan over that 4th hole?
Old 07-01-2020, 11:12 PM   #15
50fordcoupeman
50fordcoupeman's Avatar
My avatar has a 302 with a 6 blade puller flex fan one inch from the radiator. The radiator sits in front of the air deflector sheet metal (correct terminology?). There is no shroud but the caveat is no AC either. Absolutely no overheating issues. Could you move the radiator forward to get the clearance you need? Good luck
50fordcoupeman is offline   Reply With Quote
Old 07-01-2020, 11:18 PM   #16
mrtexas
mrtexas's Avatar
Can lower the radiator by a few inches with lots of welding or move radiator in front of air deflector sheet metal but not the AC condenser. Lots of options. Will try the 16" pusher and 2 9 inch pullers. Pusher in front of the radiator and 2 pullers behind. Fan shroud would then only be 10 inches tall and mostly holes for the 2 pullers. Thanks for all the experience and ideas! Have the 16 inch pusher and will order the 2 pullers.
Is best cooling with crank mounted fan?
Palindromes:
Do geese see God?
Old 07-01-2020, 11:43 PM   #17
V8COOPMAN
V8COOPMAN's Avatar
I'm assuming the sheet metal in front of the radiator is necessary for hood fitment?
Looking at the rounded rise and curvature of that sheet metal panel, as well as the rubber-looking gasket/seal on top of it, and comparing that shape with the curved external body shape of the blue hood below, that assembly seems to be an air dam of sorts when the hood is closed and the inner hood conforms to the top of that dam. This is designed to prevent HOT air that has already passed thru the radiator from being forced back forward OVER the top of that dam, only to be sucked thru the radiator again....at a higher temperature. Same purpose as the flat block-off plates that we '40 Ford guys install horizontally between the top of grill and upper radiator tank.
Seems like a crank-mounted fan would be too low. I would never put a condenser behind the radiator. Doing so would have hot air from radiator trying to remove heat from the condenser. Ambient air should be 80 to 100 degrees below condenser temp on a hot day. DD
T5 W/TORQUE TUBE
Old 07-01-2020, 11:56 PM   #18
mrtexas
mrtexas's Avatar
Crank mounted fan would be near center of radiator. But there is room in front of the deflector only for the radiator and not the condenser. Pusher would be top 16 inches of radiator. Pullers would be in bottom 10 inches of radiator. Radiator is around 24 inches tall.
Palindromes:
Do geese see God?
Old 07-02-2020, 12:08 AM   #19
V8COOPMAN
V8COOPMAN's Avatar
If crank-mounted fan is above bottom tank, that placement is optimum. Is that radiator clean inside? I'm not sure why you're having a hard time cooling the engine. Whatever you do, don't let temptation situate that condenser behind the radiator. The result will turn-out to be "not cool" (couldn't resist that).
By any chance, is there some sort of abnormal blockage at lower, rear of engine compartment hindering the exhausting of hot air out the bottom, rear of engine compartment? DD
T5 W/TORQUE TUBE
Old 07-02-2020, 03:19 PM   #20
mrtexas
mrtexas's Avatar
Just ordered two puller 6 1/2 inch fans. I keep the 16 inch pusher and add the two smaller fans at the bottom of the radiator. Decided to mount the fans with 1 inch straps. Total cfm will be approximately 2,500cfm.
Palindromes:
Do geese see God?
Thread Tools
Display Modes
