Old 06-27-2020, 07:29 PM   #1
aandkt
Default Emergency BrakeCable
I have a 1936 Ford. If you put hydraulic brakes in your Ford, and ran the emergency brake cable across the driveshaft, how did you route it?? Over--Under?? Where??
Thanks
aandkt is offline   Reply With Quote
Old 06-27-2020, 08:03 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Emergency BrakeCable
Thanks
Cables route UNDER the torque tube. DD
T5 W/TORQUE TUBE
It's interesting that so many people know SO MUCH stuff....that just ain't so!
Old 06-27-2020, 11:44 PM   #3
Bursonaw
Bursonaw's Avatar
Mine originally us under the torque tube. I did not like the way it worked on my car, because of the location of the
E-brake handle, the cable did not pull square and the passenger side brakes would work correctly but the driver side would not engage fully.
I used the original mechanical brake actuator.
I drilled a 1 hole in the frame with a step drill and used a brake rod from a Model A cut and bent to length.
Works like Henry Ford designed it himself. Now I can lock up the rear wheels with the E-brake.
Sent from my iPad using Tapatalk
Bursonaw is offline   Reply With Quote
Old 06-28-2020, 01:10 PM   #4
aandkt
Thanks for your prompt and very descriptive reply. I neglected to mention a very important fact-- I have an open Ford Bronco drive shaft.
I need to cross the driveshaft with the drivers side cable to meet with the junction under the right side seat floor.
Any help would be appreciated.
Thanks
Old 06-29-2020, 11:47 AM   #5
Als48
On my '48 with open drive shaft, I routed the cable above the drive shaft. I had a little trouble keeping the shaft from hitting it at the clevis piece where the rear cables attach.
Al Hook
Als48 is offline   Reply With Quote
Old 06-29-2020, 08:21 PM   #6
Tim Ayers
I like this idea.
Tim Ayers is online now   Reply With Quote
Old 06-29-2020, 08:23 PM   #7
Tim Ayers
Coopman,
Would you mind taking a few close ups of the E brake routing from your pict. In a few days, I'll be doing the e brake on my roadster and I'm looking for some options. I'm not picturing how the rod slide to pull the cable in your set up.
Thanks,
Tim
Old 06-29-2020, 09:13 PM   #8
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by Tim Ayers View Post
Coopman,
Thanks,
Tim
Hey Tim....That's just a quick picture I stole off of Al Gore's internet. My '40 coupe isn't stock in that E-brake cable area. I know that Jim Pullen (19Fordy) will have about 500 pictures of what you need. Jim documents (very well) EVERYTHING! Kubarth (Kube) might even have a pic or two. Hope this helps ya!! DD
T5 W/TORQUE TUBE
Old 06-30-2020, 12:07 PM   #9
Gary in La.
Gary in La.'s Avatar
What you see here is where they torched off the cable assy that runs from the hand brake lever to the bracket on the torque tube for the radius rods. The clevis end is still attached to the cable from the rear brakes.
Gary in La. is offline   Reply With Quote
Old 06-30-2020, 02:00 PM   #10
Tim Ayers
Thanks, Gary. I guess I'm trying figure out what is that piece that the rod goes through in the bracket?
Old 06-30-2020, 03:08 PM   #11
V8COOPMAN
V8COOPMAN's Avatar
Tim.....PM 19Fordy! I know he's got a bunch of pictures of that area on his '40. I just can't find 'em on here.....yet! Jim (19Fordy) will graciously accommodate you. DD
T5 W/TORQUE TUBE
Old 06-30-2020, 03:29 PM   #12
Gary in La.
Tim, that piece is what's left of the end of the cable housing. The housing end goes through the bracket and is held in place with one of those clips as used in various places on the brake system like where the hoses go through their brackets. You are seeing the inner cable end which is a rod for the clevis.
Old 06-30-2020, 03:31 PM   #13
FlatheadTed
FlatheadTed's Avatar
If your doing a 37/38 conversion use the existing cables and hand brake ,
http://www.flatheadted.com
Old 06-30-2020, 10:00 PM   #14
Tim Ayers
Ah, got it. Thank you. Since mine car is a hot rod, the stock set up may not work. Thinking of making a pull rod for some mechanical brake rod.
Old 07-01-2020, 02:10 AM   #15
Tinker
Tinker's Avatar
Hey all the young kids don't need one. aandkt under the torque. You need at least a 39 e bracket. The ebrake is pretty universal for many years. Depends on where you have a ebrake pull. Pre 38ish was a cable system off bash. Before that was a rod system off the center mechanical brakes and a pull lever of the trans, which you have being a 36. Still works for the ebrake linkage if you didn't remove the xcross member linkage. To sorta answer the original ask. sorta...
Lot of great answers though........
Thread Tools
Display Modes
