Old 06-24-2020, 11:39 AM   #1
Jbeavers
Default Timing Help
Hello, I have a 29 Model AA and recently had to replace the lower plate due to a bad wire, anyway had to redo the timing. I started with spark advance all the way up, found TDC on timing gear, used Nu-Rex wrench adjust and now truck only starts with spark advance lever all the way down. Do I start over? Perhaps I was not top dead center when i started? Im Assuming it’s way too advanced, sounds good when running with lever all the way down but I know that’s not right and looking for a little guidance.
Thanks
Jbeavers is offline   Reply With Quote
Old 06-24-2020, 12:03 PM   #2
Russ/40
Russ/40's Avatar
Default Re: Timing Help
most likely you were in error as to TDC. Did you double check that?
Russ/40 is offline   Reply With Quote
Old 06-24-2020, 12:05 PM   #3
1crosscut
1crosscut's Avatar
Jay did you have the body of the distributor on and turn the pointer on the wrench to the #4 post on it or did you by chance not have the body on the distributor and instead put the pointer at the #4 spark plug?
If you had it at top dead center, advance lever all the way up and the spark control arm touching the passenger side of the distributor body and the nurex touching the #4 contact on the body it should be pretty darn close to spot on.
Another possibility is you may not have had the screw turned tight enough and the rotor moved.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 06-24-2020, 12:06 PM   #4
Ruth
Thanks
First, what are your points set at. Nu-Rex wrench doesn't work well if points are not set correctly ~.020. Sounds to me your are too far retarded if you have to advance the lever that far to get it started.
Ruth
Old 06-24-2020, 12:22 PM   #5
30 Closed Cab PU
Picture shows where rotor is point correctly to spark plug oone when at TDC - check and see if your is correct. Lookikn from passanger side of the motor.
Other picture shows were wrench should be when timed - wrench pointing towards firewall
30 Closed Cab PU is offline   Reply With Quote
Old 06-24-2020, 12:26 PM   #6
ryanheacox
ryanheacox's Avatar
Another thought, did you bend the terminal on the wire from the lower plate to the points at a 90 degree angle? I didn't at first when I did mine and would only start with the spark down because otherwise the terminal was grounding against the spring between the plates. Hard to start with no spark, imagine that!
ryanheacox is offline   Reply With Quote
Old 06-24-2020, 12:31 PM   #7
30 Closed Cab PU
Pictures.
One of the rotor when it is at TDC cylinder 1 - check to see if you get the with the timing pin located properly .
Other picture is the wrench is set properly timed - wrench handle toward fire wall.
(spark lever at full retard/up).
Old 06-24-2020, 03:12 PM   #8
Patrick L.
Patrick L.'s Avatar
left lever up
points set to .020"
TDC found with timing pin
distributor cam notch toward #1 pin in cap [ pointing toward right fender]
distributor spins CCW
set cam so ramp just contacts points block with backlash removed.
tighten cam screw, recheck as cam can move.
any more turn of cam CCW or pulling the lever down a click or two will open points. [ a continuity meter works well ]
timing is now set correctly
Old 06-24-2020, 05:01 PM   #9
Jbeavers
Yes I thought about this also, I did bend it but maybe not enough, was going to recheck it
Old 06-24-2020, 05:04 PM   #10
Jbeavers
Hey Dave thought I would hear from you I did it all as you stated
Old 06-24-2020, 05:05 PM   #11
Jbeavers
Yes I did double check the points at .020
Old 07-06-2020, 11:15 AM   #12
Jbeavers
Hey thanks all for the suggestions it was the lower plate wire where it connects to the upper plate was not bent in enough could see where it was making contact, all is well now and drove bing around, thanks again
Old 07-06-2020, 02:02 PM   #13
1931 flamingo
1931 flamingo's Avatar
Thanks for the feedback. It may help others.
Paul in CT
Thread Tools
Display Modes
