Old 06-15-2020, 01:13 PM   #1
buddridge
Default 37 Windshield
My 37 windshield is giving me fits ....trying to remove old dried up rubber gasket from outer groove. I've done this before, but never had this much trouble. Anyone have a method that actually worked. Thanks .
Careful if you're going to follow the Masses.....sometimes the M is silent.
buddridge is offline   Reply With Quote
Old 06-15-2020, 01:33 PM   #2
40cpe
40cpe's Avatar
Default Re: 37 Windshield
I know what you are going through. All the picks and scrapers you have, then make some.
It is important that all the old stuff is out. You will be glad when you install the new gasket.
40cpe is offline   Reply With Quote
Old 06-15-2020, 01:44 PM   #3
Lanny
Lanny's Avatar
Try heating it with a hair drier. Just enough heat to get
the job done, as you don't want to over heat the glass.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 06-16-2020, 02:41 PM   #4
real steeler
Good luck with whatever solution you find. I gave up, since the frame was rusty also. My solution was to make a completely new frame from stainless, and change the rubber design. A huge amount of effort, but worth it in the end. And it opens and shuts with no leaks!! pm me if you want more info.
real steeler is offline   Reply With Quote
