04-13-2020, 01:15 PM | #1 |
Are these those special U joint washers?
I know I have them in my stash piles somewhere, but are these two those special U joint washers? If not, does anyone have one or two they'd be willing to sell?
Thanks, |
04-13-2020, 01:22 PM | #2 |
Re: Are these those special U joint washers?
Looks like you have the real deal, especially given the marks created by the shake-proof lock washer that was originally used for that application.
04-13-2020, 01:25 PM | #3 |
Yes, those are the correct ones. There is also a truck one that is similar that can work as well.
04-13-2020, 01:39 PM | #4 |
Thanks, gentlemen. David, agree about the marks.
In a previous post, someone mentioned that these are actually a "spring"? Are they designed to allow some movement under load? |
04-13-2020, 02:24 PM | #5 | |
No.....they are bellows washers.....crank the bolt down to the correct torque value and there will be no movement allowed. |
04-13-2020, 02:27 PM | #6 |
You can "Google" it. Edit: belleville, sorry Last edited by 42merc; 04-13-2020 at 02:41 PM. |
04-13-2020, 02:33 PM | #7 | |
https://en.wikipedia.org/wiki/Belleville_washer |
04-13-2020, 03:17 PM | #8 | |
You are correct in the technica/patentedl name "Belleville".......they are spring washers however, specifically designed for axial load applications. |
04-14-2020, 07:18 AM | #9 | |
I'm familiar with them from the electrical industry. Swichgear, buss & terminations are a major consumer of belleville washers. |
04-14-2020, 07:43 AM | #10 |
We also used many Belleville/spring loading type washers during the manufacture of power tools and industrial equipment at the company I worked for.
04-14-2020, 08:07 AM | #11 | |
I might also add......"Some" can get quite pricey too!!!! |
