01-21-2020, 03:53 PM | #1 |
Corn Head Grease Too Fluid for Gun
Has anybody else had the problem of corn head grease being too fluid to be pumped by a standard grease gun? The plunger just moves through the grease tube without pushing much out the nozzle.
01-21-2020, 04:16 PM | #2 |
Re: Corn Head Grease Too Fluid for Gun
Define 'standard'.....modern ???
Probably not helpful but, I had no problem using an original Model A factory grease gun. |
01-21-2020, 04:18 PM | #3 |
I have a grease gun with "00" grease in it with no problem.
01-21-2020, 05:49 PM | #4 |
yes, modern
01-21-2020, 06:13 PM | #5 |
I have the same problem, figured it was due to a cheap gun but have not tried a different one yet. It takes about 10 pumps of Corn Head grease to equal 1 pump of chassis grease and I have to keep resetting the plunger.
Maybe the original style gun would be better suited for this type of grease. Will have to try it as soon as I figure out where it is. |
01-21-2020, 06:34 PM | #6 |
The pump piston in most grease guns is pretty small so they don't have a lot of displacement. I've had troubles bleeding the air out of some guns. It can take forever on poorly designed units. I've not tried to use a suction gun such as is used for gear lube but it may work with the corn header gearbox grease. |
01-21-2020, 07:30 PM | #7 |
I used a cheap air grease gun from HF. Worked OK for me.
01-21-2020, 09:59 PM | #8 |
I use a Harbor Freight type gun as well (Princess Auto here in Canada) to pump corn head grease into the rollers on my John Deere crawler. I use John Deere corn head grease and I assume it's similar weight to other corn head grease and I don't have any problem with the gun. I also use an adapter for the button head fittings but I don't think that make a difference. I would say it must be an issue with your gun.
01-22-2020, 01:04 AM | #9 | |
01-22-2020, 02:01 AM | #10 |
If the grease gun is made to use cartriges the piston is smaller to fit in the cartrige, try it with empty grease cartrige
01-22-2020, 10:54 AM | #11 | |
01-22-2020, 05:00 PM | #12 |
Great information, as usual.
Thanks |
01-22-2020, 05:21 PM | #13 |
I have a tube in a harbor freight gun, test pumped fine. I need to pump it into my steering box. Are you guys screwing in a zerk into the fill hole for that?
01-22-2020, 09:04 PM | #14 |
01-26-2020, 09:29 AM | #15 |
I used a big plastic syringe.
01-27-2020, 11:40 AM | #16 |
The corn head may need to be stirred in the tube cannister. I put it in the refrig. for a short period to help coagulate.
I drill out an extra 2 tooth box plug and tap a hole for a small zerk. Then one can inspect fluid level and pump more if needed. |
