Old 08-31-2018, 11:43 PM   #1
1929 Roadster
1929 Roadster's Avatar
Default 29 Roadster ignition woes
I read a Post where advice was given to a guy with no spark and he was told to pull the coil wire off the Distributor cap and crank it with the key on while holding the wire A half inch from a head nut.. I did that and I have nothing . A little history , This car has not run for three years . I pulled the gas tank and treated it to get rid of the rust for good. Then I got very ill with a serious infection that I had to be hospitalized several times for and then I got cancer etc ect. So I'm finally getting to this . I have partially rebuilt the Distributor ,New points ,Timed and gapped to .020, New ignition switch & lock cable, New wire between points and lower plate, Done a continuity test from the ignition key to the points , good, continuity test for grounding, none found . I have power at both Terminal box poles and both coil poles . One problem is when doing a power check from the ignition switch body to the points (opened) the test light burns just opposite of what it should . It shows no power when locked (off)and power when unlocked(on) , So my book tells me that either it's the switch grounded or the condenser grounded or shorted .It's a new switch and passed a continuity test so I removed condenser hoping to change the outcome , no change , this condenser is supposed to be short proof so I'm befuddled . The switch body is ground ..The condenser is grounded in the front and attached to the lower plate power tab correctly. I then checked voltage at coil and terminal box . with key off 6.5V at all four. With Key on points open 6.5 all 4 and 6.5 at the power side of points. With key on points closed the voltage drops to .3 or less on points and also on the feed side (drivers side) of coil. According to what Tom Wesenberg says in this same post , the voltage should drop on the opposite side. So I took condenser out again and virtually everything remained the same . Can you advise my next step Thanks Jeremy
1929 Roadster is offline   Reply With Quote
Old 08-31-2018, 11:56 PM   #2
fordcragar
fordcragar's Avatar
Default Re: 29 Roadster ignition woes
PM sent.
fordcragar is offline   Reply With Quote
Old 09-01-2018, 12:50 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Key on and point open, then you should have battery voltage all the way to the movable points contact. Short to the other contact with a screwdriver off and on several times, and you should have a hot blue spark to a head nut with the coil wire 1/4" away.
With the key on and points closed, both points contacts should show 0 volts.
Old 09-01-2018, 01:16 PM   #4
1929 Roadster
Ok , Thanks Tom, I am getting .3 volts with key on points with points closed. Also .3 volts on the feed side (Driver side) of coil .In a past post you said it should be zero on the other side(passenger) Am I getting this right? Does this indicate a short. ,Or can I take .3v as zero? . I will try the head nut spark test again . Any other advice is welcome ..Jeremy
Old 09-01-2018, 07:51 PM   #5
Pilotdave
Pilotdave's Avatar
Jeremy, assuming that your test gear is accurate, 0.3 volts suggests that something isn't right. The challenge is figuring out what that might be without laying eyes on the car! Are you near any members of a Model A club? I bet that there's someone who would come to the scene of the crime and help you. Although you will get a ton of good information on here, having an experienced Model A person walk through the situation with you might be the best thing to do. Good luck sorting this out!
Pilotdave is offline   Reply With Quote
Old 09-01-2018, 11:28 PM   #6
Tom Wesenberg
As Dave said, it should be 0 volts at the points, so maybe the distributor body isn't grounding through the head as well as it should. Try a jumper wire from a good ground to the condenser ground screw and see if you can now get 0 volts at the points contacts. I have a feeling you are using a digital meter. I like to use analog meters when working on cars, especially the Model A.
Old 09-02-2018, 09:19 AM   #7
1929 Roadster
Yes ,I am using a cheap multimeter. OK I will try that . THANKS to both you and Dave . I am also going to double check all my wire connections . I also have an analog meter I will try that as well.
Old 09-02-2018, 09:50 AM   #8
eagle
eagle's Avatar
.3v on point side of coil, with points closed, is good. However, on the other side of the coil, even with points closed, you should have near battery volltage. You can run a quick test by running a wire from battery to the power side of the coil. Make sure all the connections from the power side of the points are clean and tight to battery. For testing, you don't even need the condenser. If you have it out, leave it out until you get the spark working. Remember, battery side of coil should ALWAYS be battery, point side of coil should be battery with points open, near gnd with points closed.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 09-03-2018, 07:58 AM   #9
Corley
Jeremy, where in Washington are you located? If anywhere near Vancouver then I'd be happy to swing by and get you going. That is Vancouver Washington, not Vancouver Canada... This should not be a different fix.
Corley
Subscribed to the KISS principle!
Corley is offline   Reply With Quote
Old 09-03-2018, 11:00 AM   #10
1929 Roadster
to : Corley. Other end of the state ,near Vancouver BC. Thanks for the come back .
Old 09-03-2018, 11:39 AM   #11
Ernie Vitucci
Good Morning...You might consider contacting the two big Model A Clubs on the net. MAFCA (The Model A Ford Club of America) or MARC (Model A Restorers Club) and see which club has a chapter close to you. Contact that chapter and they will be happy to help you get the old girl running. It is always good to belong to the local chapter as you will learn a great deal and make wonderful friends. Nice people own almost all of the old cars. Ernie in Arizona
Ernie Vitucci is offline   Reply With Quote
Old 09-03-2018, 04:33 PM   #12
1929 Roadster
Ok progress made, I cleaned all the carbon deposits off the coil head , rechecked all wires and tightened all connections, and now have white spark at the points, and now with only .01-.03 volts at points and ignition pole of the coil when points are closed ,an improvement over .3 volts. The coil wire to head nut test will not spark at 1\4 inch it has to be nearly touching the nut and it's not a blue spark ,but white like at the points . No spark seen at the plugs . Tried Tom's condenser to ground check ,no improvement . Distributor is well grounded. I'm positive the wiring is correct ...Doesn't seem like it's in the wiring. Since the coil to head nut test fails, could it be a bad coil ? They don't have a reputation of failures ..How do I test the coil ? What next? I know I'm going to get there ...With your help I have to .I checked the continuity on the coil to the rotor and all seems good there. It was running fine before with the current rotor ,cap ,body etc. Thanks Jeremy
Old 09-03-2018, 05:04 PM   #13
1955cj5
1955cj5's Avatar
Did you clean the contact surfaces of the points?
If you have power at the point arm but no spark at the plugs it may be the contact surfaces are corroded....I had to clean mine this spring.....
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 09-03-2018, 05:20 PM   #14
1929 Roadster
Yes they are new points ,but I cleaned them with very fine grit emory cloth .
Old 09-03-2018, 06:14 PM   #15
Pilotdave
Pilotdave's Avatar
A white spark from the coil lead to the block isn't what you should have; the goal is a blue spark that will jump about a quarter inch....reread Tom's post #3! Though I'm not a fan of switching parts until a problem is cured, in this case I would try replacing the condenser and/or the coil and see what happens. You mention cleaning carbon deposits off the coil - perhaps that indicates a problem there. Do one at a time and see if the problem goes away.
Old 09-03-2018, 11:47 PM   #16
Tom Wesenberg
I'd try another condenser first, as they fail more often than the coil. No fix with a new condenser, then try a new or known good coil.
Old 09-03-2018, 11:47 PM   #17
1929 Roadster
Thank you pilot Dave . Yes I understand I am looking for a 1/4" blue spark , that is why I mentioned that it was only white. Before I had zero spark at the coil wire ,so there is improvement . I have a new condenser and I'll try that first, before buying a new coil. The new condenser ,( from Snyder's) is about 1/4 inch too long so I will need to buy a new longer screw and stick a conducting spacer where it grounds to the Dist. body. I told Snyder's about this problem and they responded that all I need to do is bend the lower plate contact tab in a z shape to accommodate the longer length . But there is not enough tab to do it ...But I can make it work ...I'll be going to town tomorrow afternoon so I'll get back here with my result , probably on Wednesday. Thank you for your input .
Old 09-04-2018, 09:09 AM   #18
katy
If you're getting a big spark at the points, that suggests a bad condenser.
Play it again Sam.
Old 09-04-2018, 11:50 AM   #19
1929 Roadster
Katy, Thanks ,no I'm not getting a blue spacrk at the points, its white .Thank you Tom,Pilot Dave,Ernie, Cj5,Corely,eagle,Katy and fordcrager...I really appreciate your help ... I will buy a long screw to try the new condenser ,I don't have a spare coil so I'll have to buy one.
Old 09-04-2018, 11:55 AM   #20
Tom Wesenberg
I've always been able to bend the ground tab at a slope and use the original grounding screw. I'm surprised that your's doesn't reach OK.
Thread Tools
Display Modes
