04-08-2023, 02:00 PM | #1 |
Converting heater to 12volts
Converting a 46 Ford coupe.Tried to use a heater motor from NAPA # 655-1020 (61-63 Chevy truck)but about 1/2-3/4 inches too long.
Any suggestions regarding what motor to use or other procedures would be appreciated….thanks Last edited by dono50; 04-08-2023 at 02:04 PM. Reason: Clarification |
04-08-2023, 02:19 PM | #2 |
Re: Converting heater to 12volts
What was too long? the body of the motor or the shaft? If it was the shaft you can cut it to make it shorter.
04-08-2023, 02:26 PM | #3 |
The body of the motor, I did cut the shaft too.
04-08-2023, 07:00 PM | #4 |
I ran my avatar 6v heater on 12v for many years with no problems.
04-08-2023, 07:36 PM | #5 |
I found a 12v computer fan that fit my heater. Cheap and works good.
04-09-2023, 03:26 AM | #6 | |
Has been running on 12 volts as needed for well over 20 years. Only difference is it runs faster just like the starter motor.
04-09-2023, 03:35 AM | #7 |
04-09-2023, 05:15 AM | #8 |
Hey pal, you need A/C down there not heater, Happy Easter
04-09-2023, 07:55 AM | #9 |
I use one these they work great.
https://vintageautogarage.com/heater...00-watts-hr02/ |
04-09-2023, 08:15 PM | #10 |
04-12-2023, 11:08 PM | #11 | |
04-13-2023, 08:49 AM | #12 |
dono, I used a motor from Dennis Carpenter PN B6A-18527-B in my '46 Ford but it was over $100. About a month ago someone also asked about a 12V motor and someone posted a suggestion for almost the same motor for half the price. If you search this site you might be able to track down that post.
