Old 05-18-2018, 11:27 AM   #1
onmyossa
Default Spoke wheels for my '37 tudor
I've got a '37 tudor and want to install some 16" Ford spoke wheels to the car. Since the original wheels and hubs are not compatible with the spoke wheels I need to know what I need to do to adapt the spoke wheels. I'm thinking I need to change the hubs to accommodate the spokes but don't know which hubs to use or what other parts I need to change out. Any help would be appreciated.
Thanks,
onmyossa is offline   Reply With Quote
Old 05-18-2018, 11:58 AM   #2
deuce lover
deuce lover's Avatar
Default Re: Spoke wheels for my '37 tudor
Has your '37 been converted to hydraulic brakes?
deuce lover is online now   Reply With Quote
Old 05-18-2018, 03:35 PM   #3
RalphM
RalphM's Avatar
Later hubs, drums will work, but you will have to put spacer plates on them for the spoked Wheels to fit properly.
When I say later I mean 1940 to 1948
RalphM is offline   Reply With Quote
Old 05-18-2018, 06:06 PM   #4
Charlie Stephens
Here is a link to show the spacer plates Ralph was describing and the reason you need them. All of the wire wheels when run on the later hydraulic drums need them. Don't leave home without them or eventually the wheels will develop cracks at the bolt holes. https://www.fordbarn.com/forum/showt...=1#post1286293
Charlie Stephens
Old 05-21-2018, 07:43 PM   #5
onmyossa
Nope.
Old 05-21-2018, 07:49 PM   #6
onmyossa
Thanks Charlie for the info!
Old 05-22-2018, 05:07 AM   #7
JM 35 Sedan
JM 35 Sedan's Avatar
Here's another post discussing spacer rings vs spacer plates when using early Ford wire wheels on '40 to '48 drums.
https://www.fordbarn.com/forum/showt...t=Spacer+rings
John
