Old 07-31-2016, 09:33 AM   #1
u.cremer
Default Model A Ford 1928 Generator.
Hello. I'm from Germany and i need help . When I turn the light on, the current drops to such an extent that there is misfiring. Light out, and it is ok. Ammeter on 8, with light on -4. What should I do.
u.cremer is offline   Reply With Quote
Old 07-31-2016, 09:55 AM   #2
Art Newland
Art Newland's Avatar
Default Re: Model A Ford 1928 Generator.
Maybe your battery just has a very low charge on it? If you are going to be pulling more power out of the battery, than you are putting in, it had better be charged well.
Art Newland is offline   Reply With Quote
Old 07-31-2016, 10:16 AM   #3
u.cremer
It's a new Battery, new Relay with Diode.
Old 07-31-2016, 10:20 AM   #4
Mitch//pa
Maybe you have a short in your headlights back feeding... Check the pig tails and conduit connections common areas... Try disconnecting each headlight one at a time and retest..
Or other wiring issues
Old 07-31-2016, 10:25 AM   #5
u.cremer
Ok. And I will interpose a fuse everywhere.
Thanks
Old 07-31-2016, 02:37 PM   #6
Art Newland
If you have a volt meter, it would be nice to know that the voltage is indeed OK. How fast is the engine running while getting those amp readings? When I still had a generator, I had the third brush set for low current, headlights on, driving down the road at speed, was still showing -10 amps. You would think if there was indeed a short in the lighting circuit, it would show more than -4 amps discharge. Make sure your battery connections are clean and tight and the grounds are good.
Old 07-31-2016, 03:09 PM   #7
Patrick L.
Patrick L.'s Avatar
A 12 amp draw doesn't sound too high to me depending on what size bulbs you are using. If your high beams are 50cp, it sounds about right to me.
But, the original type headlight connectors are famous for grounding/shorting. So there could very well be a problem there if the bulbs are of lower cp. So, I too would recommend taking a good look at them. I've been known to eliminate those connectors and hard/ through wired them.
Old 07-31-2016, 05:00 PM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
I like and use original connectors..............repro connectors aren't so great and sometimes short to each other or to ground. Put on a welding helmet and look at the headlamps to make sure both filaments aren't lighting up at the same time.
Old 07-31-2016, 11:00 PM   #9
Mike V. Florida
Mike V. Florida's Avatar
New battery does not always mean good battery.
As suggested place a meter on the battery with the car running, turn on the lights and see what the voltage is.
Old 07-07-2020, 04:54 AM   #10
Ford Acar
Thanks,Tom. Are you saying that only the one filament should light on the Bright setting?
Ford Acar is offline   Reply With Quote
Old 07-07-2020, 06:23 AM   #11
john charlton
john charlton's Avatar
On high beam both filaments should not be lit ,if they are there is a fault most likely in the socket . High beam has the lower filament lit . Low beam has the upper filament lit
John still in Suffolk County England .
john charlton is offline   Reply With Quote
Old 07-07-2020, 10:40 AM   #12
30 Closed Cab PU
Deleted post, John's post above has same info.
30 Closed Cab PU is offline   Reply With Quote
Old 07-07-2020, 11:33 AM   #13
rotorwrench
rotorwrench's Avatar
This is an oldy.
rotorwrench is online now   Reply With Quote
Old 07-07-2020, 12:03 PM   #14
30 Closed Cab PU
Originally Posted by rotorwrench View Post
This is an oldy.
True, probably someone reading old info and needs clarification, or has a problem and is researching.
