Old 07-09-2016, 03:27 PM   #1
funf
Default Carburettor Spares
Hello,
I hope I can find the answer to a little problem that I have with my Model A. Having trawled the search engine here plus my own observations, I believe that my car is suffering from the stuck float valve syndrome. Now normally I would just order some new parts from one of the vendors here in England; however. It is not a normal Model A carburettor that I recognise hence my problem. I am quite happy with the carburettor, it has an adjustable main jet so that with a colourtune plug and by confirming things by reading the spark plug colour, I can get the mixture spot on. It also has an adjustable idle mixture screw so that setting can also be made spot on. I have had as high as 23mpg on a run at 45 miles per hour so economy appears reasonable. ( note that English gallons are different to US ones - 1 imperial gallon = 1.2 US gallons).
So to my question, can anyone please tell me the model of carburettor in such detail that I can order spares, and also vendors.
Identifying mark is solely on the side adjacent to the engine and says " Zenith made in USA". No other discernible markings. I have some images and an exploded diagram that I found on the internet that seems to match what I have.
Thanks in anticipation,
Stuart
ps for some unfathomable reason It seems I can only upload one image at a time, I hope this one is sufficient, or maybe some person cleverer than I can tell be how to upload multiple images.
Stuart
funf is offline   Reply With Quote
Old 07-09-2016, 04:17 PM   #2
Bob C
Default Re: Carburettor Spares
Here's a couple of links.
http://www.autotestsys.com/Merchant2..._Code=ZEN13922
http://dmacweb.com/documentation/tec...th-updated.pdf
Bob
Old 07-10-2016, 12:37 PM   #3
funf
Hello Bob,
Thanks very much for your most welcome reply. With a number for the carburettor I have googled spares, found what I want and ordered them.
This barn is indeed a most remarkable place, it's like the Univerity of the Model A, all knowledge is here.
Cheers,
Stuart
Old 07-10-2016, 02:42 PM   #4
richsfords
richsfords's Avatar
Thumbs up Re: Carburettor Spares
Never a graduate from UMA (Univ. of Model A) cause the learning never stops.
Richard in New Bern.
When everything seems to be going against you, remember that the airplane takes off against the wind, not with it - Henry Ford
richsfords is offline   Reply With Quote
Thread Tools
Display Modes
