Old 06-28-2016, 07:10 PM   #1
LP
Default 53 ford brake pedal
Just replaced master cylinder ,wheel cylinders ,and hoses on my 53 Customline V8.
The master and the cylinders are made by Dorman. In an earlier post I was having leaking issues but have that under control. Thanks to all who replied.
When trying to bleed the brakes I could never get the pedal to pump up more than an inch from the floor. The brakes grab but not until they go all the way down. I looked under the dash and it appears that the push rod does not make contact with the master cylinder right away. it seems to travel about an inch before making contact although I did not measure the exact distance.
Also the brake hoses are really close to the kingpin and on the driver side it rubs slightly.
Any help would be appreciated
LP
LP is offline   Reply With Quote
Old 06-28-2016, 07:19 PM   #2
19Fordy
19Fordy's Avatar
Default Re: 53 ford brake pedal
Please post photos. The person who did the previous work may have done a very poor job with incorrect parts.
Old 06-28-2016, 09:06 PM   #3
Barlea
Front wheel cylinders may be on the wrong side.
Barlea is offline   Reply With Quote
Old 06-28-2016, 09:59 PM   #4
petehoovie
petehoovie's Avatar
DOT 3 or DOT 5 fluid???
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 06-29-2016, 09:03 AM   #5
Robz51
Robz51's Avatar
I had terrible experience with DOT5 fluid. My brakes cylinders leaked and one drum locked up and the brake light switch went crazy before it failed. Problem is you have to replace all cylinders and flush the system to get it out.
Rob
Robz51 is offline   Reply With Quote
Old 06-29-2016, 04:39 PM   #6
LP
I thought about that ... Ill try it soon. I know I put the correct one on according to the part number though. Thanks
Old 06-29-2016, 04:40 PM   #7
LP
I'm pretty sure it is Dot 3 fluid
Old 06-29-2016, 04:43 PM   #8
LP
I was still wondering about the travel in the brake rod though. I'll work on some of the suggestions soon Thanks to all LP
Old 06-29-2016, 05:46 PM   #9
V8 Bob
V8 Bob's Avatar
The (manual) system push rod normally is retained by a clip in the master cylinder piston, or the brake pedal has a return stop to keep the clearance around 1/16". Something on your car is not right, to have very excessive push rod clearance.
V8 Bob is online now   Reply With Quote
Old 06-30-2016, 07:55 AM   #10
Big Red 51
Big Red 51's Avatar
Smile Re: 53 ford brake pedal
LP, I had the gap problem of about one inch and found that the M/C push rod plastic cap ( B5A-2142) was not on the MC end of the brake push rod. Fixed the problem. Got mine at C&G for $7.
Don
Big Red 51 is offline   Reply With Quote
Old 06-30-2016, 09:04 AM   #11
Planojc
Planojc's Avatar
adjust the shoes on each wheel with a brake spoon until you start to feel a drag. The adjustment opening is on the back side of the backing plate at the bottom. This will bring your pedal up.
Planojc is offline   Reply With Quote
Old 07-01-2016, 11:20 PM   #12
59ab
I have owned 3 53 Fords. The rod that pushes the master cilinder is bolted to the brake petal. The head of the bolt has a shoulder that is off set from the rest of the bolt. By turning the hex head of the bolt this off set acts like a cam and pushes the rod in or out.
I do not think it will move the rod an inch. May be some one put the wrong rod on your car.
Hope this helps.
Eddie
59ab is offline   Reply With Quote
