04-12-2016, 05:15 PM | #1 |
rear seal on a t-5 transI
I have a T-5 trans in my 1948 F1 pickup I have a problem with the rear seal leaking. I have change it two times and still leaking. Thanks for any info. BOB.
04-12-2016, 05:51 PM | #2 |
Re: rear seal on a t-5 transI
Are you buying the seal kit that comes with a new bushing too, maybe too much play is making the seal leak?
Throttle Benders Est. 1949
04-12-2016, 05:54 PM | #3 |
Are you referring to the seal that the driveshaft yoke goes into? If it is not sealing are you sure the surface on the yoke is in good shape (smooth, no grooves, etc.).
04-12-2016, 06:06 PM | #4 |
Thread Tools | |
Display Modes | |
