Old 05-13-2010, 09:05 AM   #1
a31vicky
Default Exhaust/Intake gasket
I have used a black fiber 1 piece gasket in past with excellent results. Don't remember where I purchased. Does anyone know of a supplier? If not, what is best product currently on market. Thanks. a31vicky
a31vicky is offline   Reply With Quote
Old 05-13-2010, 09:45 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Exhaust/Intake gasket
I've only used the copper with filler in the center and had excellent results. I also use the gland rings, except due to slight warpage I can't get the rear one in my 28.
Old 05-13-2010, 09:53 AM   #3
Mitch//pa
i use the copper also and usually replace the studs and manifold dish washers and brass nuts. it gives it a clean fresh look
